Jump to visualization page when ID is received
Hey Everybody,
I can't get the example script :"Open IP camera visualization page when intercom call is received" working.
I also want to use this functionality for more triggers, so I was hoping for a script in which the visualisation ID is triggert.
So for example: http://IP-ADDRESS/scada-vis/#18   This triggers by sending "18" to an 2 byte unsigned integer.
Anybody who can help me?
Thanks!
Here is a custom JS to do that:
$(function(){   if (typeof grp != 'undefined') {     grp.listen('1/1/1', function(object, state) {       if (state == 'value') {           showPlan(object.value);             }     });   } });
(31.05.2020, 07:39)Erwin van der Zwart Wrote: Hi,
Hi Erwin,
Many thanks!  Works like a charme!
Added time out, so it hops back to startscreen (i defined).
if (plantimer){
        clearTimeout(plantimer)
          plantimer=setTimeout(function(){
              showPlan(XX);
          }, 60000);
1.
  Erwin,
1 question in addition to this. Can you also make the visualisation active?  I now use dimming. So the visulaisation is shown, but the screen is dimmed.
Add this line to your code:
$('.modal-backdrop').addClass("hide");
(31.05.2020, 21:33)Erwin van der Zwart Wrote: Hi,
Hi Erwin,
Thx again for the quick response, however I now find it difficult to apply in my code. Can you please help.
My code:
var plantimer;
$(function(){
      grp.listen('1/1/1', function(incomingEvent, eventType) {
        if (eventType == 'value') {
          switch(incomingEvent.value){
              case 1:
                  showPlan(11);
                  break;
              case 2:
                  showPlan(7);
                  break;
              case 3:
                  showPlan(38);
                  break;
  if (plantimer){
              showPlan(1);
          }, 60000);
Just add it after each showPlan call where needed
(01.06.2020, 09:49)admin Wrote: Just add it after each showPlan call where needed
Thx, it was the ";" I still had in there, why it did not work :-)
