Control BenQ projector with RS232
I have some trouble to send control commands ON/OFF to a BenQ MS517H usin gfollowing event based script.
12345678910111213141516171819202122
require('serial') device = '/dev/ttyUSB0' port = serial.open(device, { baudrate = 9600, parity = 'none', stopbits = 1  }) -- get value of KNX object value = event.getvalue() if (value == true) then   -- send power on command with returns to make them stick   char = "<CR>*pow=on#<CR>"    port:write(char) else   -- send power off command   char = "<CR>*pow=off#<CR>"    port:write(char) end -- close port port:close()
.pdf   MS517H RS232 koder.pdf (Size: 1.49 MB / Downloads: 16)
<CR> is \r (carriage return):
char = "\r*pow=on#\r"
(20.05.2020, 10:30)victor.back Wrote: Hi
I had an issue with benq once before, I think the solution was to replace <CR> with hex terminator 0D
Try,
char = string.char(“0x0D”)..”*pow=off”..string.char(“0x0D”)
Can you test the command by sending it from a terminal from pc
(20.05.2020, 10:33)admin Wrote: <CR> is \r (carriage return):
Thanks, changed that but no success.
Try,
I tried with Tera term but didnt get it to work.
Managed to send power on command from a Zennio SKX Open with the HEX code 0D2A706F773D6F6E230D.
Sorry but I didnt understand how to change the script with your solution. Im an beginner in LUA.
0D2A706F773D6F6E230D is the same as "\r*pow=on#\r"
Maybe the serial port settings are wrong or the cable is the problem? Are you using straight or cross-over cable?
The problem chould be the cable. I´ve used an old cable that I have used for programming before, but don´t know if its straight or cross-over.
What type shcould i have?
Usually you need cross so RX on one side is connected to TX on the other side.
