30.04.2020, 06:46
					Remote Access Visualization
		30.04.2020, 06:50
		Does the same thing happen locally? Maybe there's IP conflict?
		30.04.2020, 07:21
	(30.04.2020, 06:50)admin Wrote: Does the same thing happen locally? Maybe there's IP conflict? Locally it is perfect, and with the public IP I also access without problems. I do not know if it has something to do, but I just created an access without being an Admin, and I was able to access it for the first time, with some slowness but I agreed with 4G, with WIFI impossible. I was wondering if in LM I had to configure something that I did not know, but when I got access I see that the problem may be in some kind of problem in the network configuration. I will continue searching ... thank you very much!
		13.08.2020, 10:50
	(07.02.2020, 12:15)Daniel. Wrote: Hi Hello Daniel, do you have any example or manual for the VPN configuration?
		13.08.2020, 11:29
		This is very good tutorial
https://www.digitalocean.com/community/t...untu-18-04
Ctrl+F5  |
