Send image from IP camera to Telegram
I have an IP camera working and I can view it trough my logic machine.
The next step I like to reach is to send the snapshot to my telegram.
I have already configured my telegram, I can send messages. But it's impossible to send a snapshot.
I have a DAHUA camera, and the url to view the snapshot is this:
Http: // user: password@cameraip/cgi-bin/snapshot.cgi
I can view it in chrome without problems.
I try to send it with "sendphoto" command and with the example from here, in this case send through email.
https://forum.logicmachine.net/showthread.php?tid=1061
I do not know what else to do. Can someone help me?
First you need to retrieve the image using http request.
Then you can send the image using this example. filedata variable must contain image data as a string, change PUT_CHAT_ID_HERE and PUT_BOT_TOKEN_HERE placeholders
require('ssl.https') boundary = os.date('%d%m%Y%H%M%S') filedata = '...' -- snapshot image data as a string params = {   {     name = 'chat_id',     value = 'PUT_CHAT_ID_HERE',   },   {     name = 'photo',     filename = 'snapshot.jpg',     ctype = 'image/jpeg',     value = filedata,   } } body = { '--' .. boundary } for _, param in ipairs(params) do   line = string.format('Content-Disposition: form-data; name=%q', param.name)   if param.filename then     line = string.format('%s; filename=%q', line, param.filename)   end   body[ #body + 1 ] = line   if param.ctype then     body[ #body + 1 ] = string.format('Content-Type: %s', param.ctype)   end   body[ #body + 1 ] = ''   body[ #body + 1 ] = param.value   body[ #body + 1 ] = '--' .. boundary end -- last boundary body[ #body ] = body[ #body ] .. '--' -- empty line at the end body[ #body + 1 ] = '' bodydata = table.concat(body, '\r\n') resp = {} log(   ssl.https.request({     url = 'https://api.telegram.org/PUT_BOT_TOKEN_HERE/sendPhoto',     sink = ltn12.sink.table(resp),     method = 'POST',     source = ltn12.source.string(bodydata),     headers = {       ['content-length'] = #bodydata,       ['content-type'] = 'multipart/form-data; boundary=' .. boundary     }   }) ) log(table.concat(resp))
Thanks for the answer.
I put my url snapshot on "filedata" and my CHATID and BOT_TOKEN, but it doesn't work.
The log says:
* arg: 1
* number: 1
* arg: 2
* number: 400
* arg: 3
* table:
["server"]
* string: nginx/1.16.1
["access-control-expose-headers"]
* string: Content-Length,Content-Type,Date,Server,Connection
["content-type"]
* string: application/json
["connection"]
* string: close
["content-length"]
* string: 79
["date"]
* string: Thu, 13 Aug 2020 15:18:09 GMT
["strict-transport-security"]
* string: max-age=31536000; includeSubDomains; preload
["access-control-allow-origin"]
* string: *
* arg: 4
* string: HTTP/1.1 400 Bad Request
* string: {"ok":false,"error_code":400,"description":"Bad Request: IMAGE_PROCESS_FAILED"}
As mentioned before first you need to retrieve the image from your camera via http request. You cannot pass a url to the snapshot here because telegram server cannot access your camera.
Ok.
As you can see I'm a completely noob with LUA.
I will search info about that.
Thanks again.
Hello.
I have tried to retrieve the image with no results.
I have used these examples:
https://forum.logicmachine.net/showthrea...tp+request
https://forum.logicmachine.net/showthrea...64#pid9364
Can you explain me how I need to do this?
Thanks in advance.
Log what you get when sending a request to the camera. Make sure that the URL is correct and it actually returns an image not a HTML page containing the image.
require('socket.http') log(socket.http.request('http://user:password@cameraip/cgi-bin/snapshot.cgi'))
(14.08.2020, 08:08)admin Wrote: Log what you get when sending a request to the camera. Make sure that the URL is correct and it actually returns an image not a HTML page containing the image.
Sure:
* arg: 1
  * string:
* arg: 2
  * number: 401
* arg: 3
  * table:
  ["content-length"]
    * string: 0
  ["www-authenticate"]
    * string: Digest realm="Login to 5L02EC8PAGC1BC0", qop="auth", nonce="762101674", opaque="e65481894c6ae41a2f1296db7e53d66882f66471"
  ["connection"]
    * string: close
* arg: 4
  * string: HTTP/1.1 401 Unauthorized
This means that you need to use digest code example from here: https://forum.logicmachine.net/showthrea...64#pid9364
log what you get from the request:
url = 'http://user:password@cameraip/cgi-bin/snapshot.cgi' image, err, hdrs = request(url) log(image, err, hdrs)
(14.08.2020, 08:47)admin Wrote: This means that you need to use digest code example from here: https://forum.logicmachine.net/showthrea...64#pid9364
With the last code I have not had any records, instead that I had an error:
User script:21: attempt to call global 'request' (a nil value)
stack traceback:
User script:21: in main chunk
You need to copy the whole code from here: https://forum.logicmachine.net/showthrea...64#pid9364
And change the last lines as in my previous post.
(14.08.2020, 08:53)admin Wrote: You need to copy the whole code from here: https://forum.logicmachine.net/showthrea...64#pid9364
Ok, sorry. This is the log:
* arg: 1   * string: ����
EDIT
It's working, I have to put on filedata, the name without ' '.
Thanks admin.
This is my whole code:
local skthttp = require('socket.http') local skturl = require('socket.url') local ltn12 = require('ltn12') local md5sum = require('encdec').md5 local hash = function(...)   return md5sum(table.concat({...}, ':')) end local parse_header = function(header)   local result = {}   for key, value in (header .. ','):gmatch('(%w+)=(.-),') do     if value:sub(1, 1) == '"' then -- strip quotes       result[ key:lower() ] = value:sub(2, -2)     else       result[ key:lower() ] = value     end   end   return result end local make_digest_header = function(headers)   local digest = {}   for _, header in ipairs(headers) do     if not header.unquote then       header[ 2 ] = '"' .. header[ 2 ] .. '"'     end     digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ]   end   return 'Digest ' .. table.concat(digest, ', ') end local _request = function(req)   if not req.url then     return nil, 'missing url'   end   local url = skturl.parse(req.url)   local user, password = url.user, url.password   if not user or not password then     return nil, 'missing credentials in url'   end   url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil   req.url = skturl.build(url)   local source   if req.source then     local chunks = {}     local capture = function(chunk)       if chunk then         chunks[ #chunks + 1 ] = chunk       end       return chunk     end     local chunk_id = 0     source = function()       chunk_id = chunk_id + 1       return chunks[ chunk_id ]     end     req.source = ltn12.source.chain(req.source, capture)   end   local body, code, hdrs = skthttp.request(req)   if code == 401 and hdrs['www-authenticate'] then     local ht = parse_header(hdrs['www-authenticate'])     if not ht.realm or not ht.nonce then       return nil, 'missing realm/nonce from response'     end     if ht.qop ~= 'auth' then       return nil, 'unsupported qop ' .. tostring(ht.qop)     end     if ht.algorithm and ht.algorithm:lower() ~= 'md5' then       return nil, 'unsupported algo ' .. tostring(ht.algorithm)     end     local nc = '00000001'     local cnonce = string.format('%08x', os.time())     local uri = skturl.build({ path = url.path, query = url.query })     local method = req.method or 'GET'     local response = hash(       hash(user, ht.realm, password),       ht.nonce,       nc,       cnonce,       'auth',       hash(method, uri)     )     req.headers = req.headers or {}     local auth = {       { 'username', user },       { 'realm', ht.realm },       { 'nonce', ht.nonce },       { 'uri', uri },       { 'cnonce', cnonce },       { 'nc', nc, unquote = true },       { 'qop', 'auth' },       { 'algorithm', 'MD5' },       { 'response', response },     }     if ht.opaque then       table.insert(auth, { 'opaque', ht.opaque })     end     req.headers.authorization = make_digest_header(auth)     if not req.headers.cookie and hdrs['set-cookie'] then       -- not really correct but enough for httpbin       local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]')       if cookie then         req.headers.cookie = '$Version: 0; ' .. cookie .. ';'       end     end     if req.source then       req.source = source     end     body, code, hdrs = skthttp.request(req)   end   return body, code, hdrs end local request = function(url)   local t = type(url)   if t == 'table' then     return _request(table.clone(url))   elseif t == 'string' then     local req = {}     local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) })     return table.concat(req), code, headers   end end url = 'http://USER:PASS@CAM IP/cgi-bin/snapshot.cgi?1&ts=123/snapshot.jpeg' image, err, hdrs = request(url) log(image, err, hdrs) require('ssl.https') boundary = os.date('%d%m%Y%H%M%S') filedata = image -- snapshot image data as a string params = {   {     name = 'chat_id',     value = 'MY CHAT ID',   },   {     name = 'photo',     filename = 'snapshot.jpg',     ctype = 'image/jpeg',     value = filedata,   } } body = { '--' .. boundary } for _, param in ipairs(params) do   line = string.format('Content-Disposition: form-data; name=%q', param.name)   if param.filename then     line = string.format('%s; filename=%q', line, param.filename)   end   body[ #body + 1 ] = line   if param.ctype then     body[ #body + 1 ] = string.format('Content-Type: %s', param.ctype)   end   body[ #body + 1 ] = ''   body[ #body + 1 ] = param.value   body[ #body + 1 ] = '--' .. boundary end -- last boundary body[ #body ] = body[ #body ] .. '--' -- empty line at the end body[ #body + 1 ] = '' bodydata = table.concat(body, '\r\n') resp = {} log(   ssl.https.request({     url = 'https://api.telegram.org/MY BOT/sendPhoto',     sink = ltn12.sink.table(resp),     method = 'POST',     source = ltn12.source.string(bodydata),     headers = {       ['content-length'] = #bodydata,       ['content-type'] = 'multipart/form-data; boundary=' .. boundary     }   }) ) log(table.concat(resp))
This line is incorrect:
filedata = 'image'
It should be
filedata = image
(14.08.2020, 11:08)admin Wrote: This line is incorrect:
filedata = 'image'
It should be
filedata = image
Yes, I just put it in my previous post. Thank you very much again.
filedata = 'image'
It should be
filedata = image
Hello, I have tried the above methods but still cannot receive images on Telegram. Below is the log result after running resident script:
* arg: 1   * string: Error Invalid Authority! * arg: 2   * number: 401 * arg: 3   * table:    ["content-length"]     * string: 27    ["content-type"]     * string: text/plain;charset=utf-8    ["connection"]     * string: close * arg: 1   * number: 1 * arg: 2   * number: 400 * arg: 3   * table:    ["server"]     * string: nginx/1.18.0    ["access-control-expose-headers"]     * string: Content-Length,Content-Type,Date,Server,Connection    ["content-type"]     * string: application/json    ["connection"]     * string: close    ["content-length"]     * string: 79    ["date"]     * string: Tue, 22 Jul 2025 09:14:59 GMT    ["strict-transport-security"]     * string: max-age=31536000; includeSubDomains; preload    ["access-control-allow-origin"]     * string: * * arg: 4   * string: HTTP/1.1 400 Bad Request * string: {"ok":false,"error_code":400,"description":"Bad Request: IMAGE_PROCESS_FAILED"}
Can you help me solve this issue? I’m also using a Dahua camera and want to send snapshots to Telegram.
The error comes from the camera. Check if username and password are correct. Then check the documentation, the snapshot URL might be different or some option must be enabled first for snapshots to work.
(23.07.2025, 13:16)admin Wrote: The error comes from the camera. Check if username and password are correct. Then check the documentation, the snapshot URL might be different or some option must be enabled first for snapshots to work.
I copied the URL from the code into Chrome, and it successfully returned a snapshot, so where could the issue be?
It works in browser because you are already authenticated.
Change url variable as needed, run this script once and post what you get in Logs tab:
url = 'http://USER:PASS@CAM_IP...' res, err, hdrs = require('socket.http').request(url) log(res, err, hdrs)
(25.07.2025, 06:44)admin Wrote: It works in browser because you are already authenticated.
Here is what I got.
* arg: 1   * nil * arg: 2   * string: host not found * arg: 3   * nil
