Create/Delete Scheduler events
Hey,
I am trying to figure out a way to create/delete schedulers/scheduler events from scripts.
I found that you can update values in pre-existing schedulers and events but is it possible to create them from scripts?
I am currently using this to update the values within already created events.
    db:update('scheduler_events', { --Update schedulers       start_hour = startHr,       start_min = startMin        }, { name = schedEvent} )
You can insert data like this. But you have to carefully fill all fields, there's no guarantee that it will work if some field value are incorrect.
db:insert('scheduler_events', {   start_hour = startHr,   start_min = startMin,   -- remaining fields here })
