Get Current user logged
¿How can I get the current user's name that was logged in the LM?
Thanks by yor help.
In newer firmwares you can access Globals.user variable in custom JavaScript. For event scripts you can check event.meta field, but it's only set when object value is changed via UI/Visualization.
(21.10.2020, 07:10)admin Wrote: In newer firmwares you can access Globals.user variable in custom JavaScript. For event scripts you can check event.meta field, but it's only set when object value is changed via UI/Visualization.
I've found that Globals.user is not available from Custom Javascript when Schedulers opened. Is this intentionally?
Done is better than perfect
