22.10.2020, 18:26
Hello
I have a LM with almost 9000 objects, 200 Plans and 300 widgets. When I start the visualization (Touch) the first load last almost 15 seconds. Once the project is loaded in the device everything run very fast, the problem is the first load.
I know that the problems is that i have put a lot of objets in all Plans and widgets, because if I delete the half of Widgets and Plans the first loading only last 5 seconds.
Is it posible that I can choose the widgets and Plans I want to load first? The Idea is to show it to the user quicly, while in a second thread (hided for user) others widgets and plans will be loaded.
Other way could be, if I can choose what widgets or planes I want to do in first load, and the other plans and widgets dont load, and only load them if the user wants to show them.
All of this is to speed up the process of first load in the Touch visualization.
May be there is other way that I can speed up the first load, but i dont know, Could you help me please?? I know that the project is very big, and I dont want to eliminate Plans or Widgets, that is Why I ask if any one know any solution about it.
Thank you very much
best regards
Thank you very much
best regards
If you would open dev tools in your browser you would see how big load is to open this amount of data
