tag value of ocbject
Hello
i should retrieve the object tag value with the following code
------- retry TAGS for mailing dest
tbl = grp.gettags(name)
strTAGS = table.concat(tbl, ', ')
If I have more tags how can I retrieve the value of the single tag?
First tag will be tbl[1], second: tbl[2] and so on. But the table can be empty as well. Explain what are you try to do? Find if an object has a certain tag?
(01.02.2021, 09:31)admin Wrote: First tag will be tbl[1], second: tbl[2] and so on. But the table can be empty as well. Explain what are you try to do? Find if an object has a certain tag?
yes I am using the tags for various functions, in case of values, if I have more values the first value is used for or / and script, the second to send mail with differentiated address.
is it possible to see the length of the array?
thank's
Array-like table length:
len = #tbl
(01.02.2021, 10:22)admin Wrote: Array-like table length:
len = #tbl
thank you very much
