Modbus TCP Controller as Slave
Im testing if i can read via modbus tcp from another Controller in the same Network.
Im using the Modbus Slave script. However I can only write data and not read data and it always says Operation timed out, even tho it actually writes data.
Same thing if i test to read/write with QModbus.
I haven't changed the example script and tested running it every 1/5/15/60 seconds with the same outcome each time.
It should be with 0 interval. The script works I used it may times.
Thanks so much! Works fine now Big Grin such a simple solution..
