Lm2 and Lm3 ! port USB ?
Hi everybody !
I have trouble following:
Write a script to check the data via USB to the LM.
require ('serial')
if not ready then
   Ready = true
   port, err = serial.open ('/ dev / ttyUSB2')
   log (port, err)
On Lm2 will be announced:
Lua serials @ / dev / ttyUSB2; baud: 115200; parity: none, data bits: 8, stop bits: 1, duplex: full, flow: none
Such is the success!
On LM3 will be announced:
* Arg: 1
   * luaserial
* Arg: 2
   * nil
Such is successful or unsuccessful?
Plug the device was still on the LM2 and LM3 is the same USB device
Your LM2 has older serial library, that's why the output is different. Anyway, if port cannot be open your port variable will be nil and err will be a string cannot open port
Can you give me one script writes on the latest LM3?
Script to check if USB ports are open yet?
Do you need to check if port is present in the system?
if io.exists('/dev/ttyUSB0') then   alert('Port OK') else   alert('Port not found') end
good. Thank so much admin!
