13.02.2017, 16:53
Does anybody have a script to control LG smart TV over IP?
LG smart TV
13.02.2017, 16:53
26.12.2017, 18:47
(13.02.2017, 16:53)Desislav Wrote: Hello, Hello, Yes is it possible to change this python script to lua ? see : https://github.com/ubaransel/lgcommander This is a script to control a LG smart TV.
14.05.2018, 09:49
anybody was try to control from LUA ?
14.05.2018, 10:01
Here is websocket script. I've tried, but something did wrong. If anyone could use it and make LG TV control, it would be great.
https://forum.logicmachine.net/showthrea...=websocket
13.07.2020, 17:54
(This post was last modified: 13.07.2020, 17:55 by ro_ki@tut.by.)
Attached you can find the library to control LG TV with Web OS.
It uses Lua websocket library from here https://github.com/lipp/lua-websockets. Websocket library is also available in this forum. Just change the name of the library to yours in the coding ('user.websocket_client_sync') It was inspired by Node.JS module https://github.com/hobbyquaker/lgtv2, you can also find a list of commands and configuration instructions there. Coding is published as is , errors are possible ![]() The following command will turn Off the LG TV . 2 constants below are the IP address of the LG TV and the KNX group address to store the handshake key. Code: lg_execute_command(LGTV65_IP, LGTV65_KEY, "", "request", "ssap://system/turnOff", "")
31.10.2020, 13:02
thanks a lot!! for your contribution, it works perfect on my system
05.11.2020, 18:55
what it could be? See such errors in log: * arg: 1 * string: Connection close result: * arg: 2 * bool: true * arg: 3 * number: 1000 * arg: 4 * string: * string: {"type":"error","id":"4102853981","error":"401 insufficient permissions (not registered)","payload":{}} * string: Connection timeout Alex
Finally all is OK. When I tried send command (from other room) TV showed info should we accept new connection? (This active some seconds..). Just today found out this
With TV remote control we need accept request and all working ![]() A little instruction how to start TV work with LM (Thanks to Jose_dli user): You have to create 3 things, the first is the object type "250 byte string" without any value stored in it. It is for store the handshake/key in the first connection, in my system '32/7/0' Second load in Scripting-->User libraries-->add new library the one that you can find in https://forum.logicmachine.net/showthrea...=websocket. before load library rename it from websocket.lua to websocket_client_sync.lua And third, copy-paste script "lgtv.lua" at the end of Scripting-->common functions I execute lg_execute_command("192.168.0.20", '32/7/0', "", "request", "ssap://system/turnOff, "") instead of lg_execute_command(LGTV65_IP, LGTV65_KEY, "", "request", "ssap://system/turnOff", "")
22.03.2021, 09:23
(06.11.2020, 21:29)AlexLV Wrote: Finally all is OK. When I tried send command (from other room) TV showed info should we accept new connection? (This active some seconds..). Just today found out this this link didn't work: https://forum.logicmachine.net/showthrea...=websocket. could you post a working link or the LUA user script for the websoket @ admin regards,
Best Regards,
22.03.2021, 09:24
Correct link: https://forum.logicmachine.net/showthread.php?tid=1294
(13.07.2020, 17:54)ro_ki@tut.by Wrote: Attached you can find the library to control LG TV with Web OS. how to set the payload commands like If I want to change the volume or send a notification: Like this one from GitHub request('ssap://system.notifications/createToast', {message: 'Hello World!'});
Best Regards,
22.03.2021, 12:17
You need to encode the payload using JSON:
Code: payload = json.encode({ message = "hello" })
22.03.2021, 12:26
(22.03.2021, 12:17)admin Wrote: You need to encode the payload using JSON: great thanks Admin
Best Regards,
02.06.2021, 19:33
Thank you!!! Everything works!!!
21.06.2021, 17:24
Hello again!
Is there a way to turn TV on?? I believe TV keeps LAN connection open, because Android application can turn it on. Regards, Alex
22.06.2021, 04:53
You can try sending Wake on LAN packet to it. See this: https://forum.logicmachine.net/showthread.php?tid=849
Some additional settings on the TV side might be required: https://lgcommunity.us.com/discussion/89...ake-on-lan
23.06.2021, 16:29
Thank you!!
27.06.2021, 15:23
Best Regards,
28.06.2021, 06:37
Yes this is for LG TVs. It's not guaranteed to work for all models though.
(28.06.2021, 06:37)admin Wrote: Yes this is for LG TVs. It's not guaranteed to work for all models though. thank you, admin Is there a way to know which modules are supported? I have this setting on my tv https://lgcommunity.us.com/discussion/89...ake-on-lan ,so does this mean it's supported?
Best Regards,
