Log to Vis
Hi, using an example of how to get log results to a vis frame. All works fine and have modified to only show actual message.
But I cant find a way to remove the start of each message line. like
* string: ID 1 Meter results
I only want in the vis frame to show ID 1 Meter results. on each line.
Any help would be appreciated
You can remove the text part before the ":" like this:
text = text:sub(text:find(':') + 2)
Or you can use a separate log from this example: https://forum.logicmachine.net/showthrea...26#pid1726
