e-mail triggering
I'm trying to trigger sending mail by value =1. would that be correct script?
-- make sure mail settings are set in user function library before using this function
subject = 'THERE IS ALARM'
message = 'THERE IS AN ALARM IN THE SYSTEM- PLEASE LOG IN TO VISUALISATION AND CHECK ALARM PAGE'
mail('test@mail.com', subject, message)
--trigger function
value = event.getvalue()
if (value ==1) then
  send (mail)
For boolean data type the value can be either true or false. You can simply write it like this:
value = event.getvalue() if value then   send (mail) end
I've set as advised and made sure the object in of the boolean type, but no e-mail is being sent.
The whole trigger even looks like this:
mail('mail to which e send', subject, message)
--trigger function
if value then
send (mail)
Change to variable as needed. If it does not work then check what you get in Logs tab.
to = 'user@example.com' subject = 'THERE IS ALARM' message = 'THERE IS AN ALARM IN THE SYSTEM- PLEASE LOG IN TO VISUALISATION AND CHECK ALARM PAGE' value = event.getvalue() if value then   res, err = mail(to, subject, message)   log(res, err) end
That's the fault from logs:
* arg: 1
* nil
* arg: 2
* string: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials o1sm5514363wrm.66 - gsmtp
less secure apps are activated - just in case you might ask
Did you setup email settings in Common functions?
I've got it working - just retyped all instead copy paste and is working
Now, one more question - if I wished to have more users then what would I need to do? add more mail addresses in the line 'to' i.e.
to = 'user1@mail.com' ; 'user2@mail.com'
Like this:
to = { 'user1@mail.com', 'user2@mail.com' }
