Turning off scroll bouncing
I am using my visu with an iPad. Sometimes people have an issue with controlling the buttons on the screens, due to the fact that the whole screen is be ‘pushed’ slightly up and down - instead of buttons being pushed or sliders moved. In that case the screen bounces elastically. Also sometimes called ‘rubber-banding’ or ‘elastic scrolling’. Hope I am clear enough with my explanation.
Though the issue is of course primarily with the user in how the the screen was touched, but having ipads installed on the wall or on a stand it hampers good control. I also see that other applications do not have this elastic effect.
Is there a wayto turn off this elastic screen effect?
Try Disable object click animation: in Vis config.
(13.05.2021, 08:14)Daniel. Wrote: Try Disable object click animation: in Vis config.
No, unfortunately doesn’t solve it.
Couple of things to try:
1. Add to Vis. graphics > Edit custom CSS:
html, body { overscroll-behavior: none; }
2. Add to Scripting > Tools > Custom JavaScript:
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137
/*! iNoBounce - v0.2.0 * https://github.com/lazd/iNoBounce/ * Copyright (c) 2013 Larry Davis <lazdnet@gmail.com>; Licensed BSD */ (function(global) {     // Stores the Y position where the touch started     var startY = 0;     // Store enabled status     var enabled = false;     var supportsPassiveOption = false;     try {         var opts = Object.defineProperty({}, 'passive', {             get: function() {                 supportsPassiveOption = true;             }         });         window.addEventListener('test', null, opts);     } catch (e) {}     var handleTouchmove = function(evt) {         // Get the element that was scrolled upon         var el = evt.target;         // Allow zooming         var zoom = window.innerWidth / window.document.documentElement.clientWidth;         if (evt.touches.length > 1 || zoom !== 1) {             return;         }         // Check all parent elements for scrollability         while (el !== document.body && el !== document) {             // Get some style properties             var style = window.getComputedStyle(el);             if (!style) {                 // If we've encountered an element we can't compute the style for, get out                 break;             }             // Ignore range input element             if (el.nodeName === 'INPUT' && el.getAttribute('type') === 'range') {                 return;             }             var scrolling = style.getPropertyValue('-webkit-overflow-scrolling');             var overflowY = style.getPropertyValue('overflow-y');             var height = parseInt(style.getPropertyValue('height'), 10);             // Determine if the element should scroll             var isScrollable = scrolling === 'touch' && (overflowY === 'auto' || overflowY === 'scroll');             var canScroll = el.scrollHeight > el.offsetHeight;             if (isScrollable && canScroll) {                 // Get the current Y position of the touch                 var curY = evt.touches ? evt.touches[0].screenY : evt.screenY;                 // Determine if the user is trying to scroll past the top or bottom                 // In this case, the window will bounce, so we have to prevent scrolling completely                 var isAtTop = (startY <= curY && el.scrollTop === 0);                 var isAtBottom = (startY >= curY && el.scrollHeight - el.scrollTop === height);                 // Stop a bounce bug when at the bottom or top of the scrollable element                 if (isAtTop || isAtBottom) {                     evt.preventDefault();                 }                 // No need to continue up the DOM, we've done our job                 return;             }             // Test the next parent             el = el.parentNode;         }         // Stop the bouncing -- no parents are scrollable         evt.preventDefault();     };     var handleTouchstart = function(evt) {         // Store the first Y position of the touch         startY = evt.touches ? evt.touches[0].screenY : evt.screenY;     };     var enable = function() {         // Listen to a couple key touch events         window.addEventListener('touchstart', handleTouchstart, supportsPassiveOption ? { passive : false } : false);         window.addEventListener('touchmove', handleTouchmove, supportsPassiveOption ? { passive : false } : false);         enabled = true;     };     var disable = function() {         // Stop listening         window.removeEventListener('touchstart', handleTouchstart, false);         window.removeEventListener('touchmove', handleTouchmove, false);         enabled = false;     };     var isEnabled = function() {         return enabled;     };     // Enable by default if the browser supports -webkit-overflow-scrolling     // Test this by setting the property with JavaScript on an element that exists in the DOM     // Then, see if the property is reflected in the computed style     var testDiv = document.createElement('div');     document.documentElement.appendChild(testDiv);     testDiv.style.WebkitOverflowScrolling = 'touch';     var scrollSupport = 'getComputedStyle' in window && window.getComputedStyle(testDiv)['-webkit-overflow-scrolling'] === 'touch';     document.documentElement.removeChild(testDiv);     if (scrollSupport) {         enable();     }     // A module to support enabling/disabling iNoBounce     var iNoBounce = {         enable: enable,         disable: disable,         isEnabled: isEnabled     };     if (typeof module !== 'undefined' && module.exports) {         // Node.js Support         module.exports = iNoBounce;     }     if (typeof global.define === 'function') {         // AMD Support         (function(define) {             define('iNoBounce', [], function() { return iNoBounce; });         }(global.define));     }     else {         // Browser support         global.iNoBounce = iNoBounce;     } }(this));
Thanks guys, works like a charm!
Did you try both at the same time? I'm wondering if only one solution is enough.
(13.05.2021, 14:21)admin Wrote: Did you try both at the same time? I'm wondering if only one solution is enough.
I now ckecked option 1 and 2 seperately
Option 2 does the trick.
Option 1 doesn't.
Ok, thanks for testing! 1st option should work but due to a bug in Safari it does not.
