Ikea Blinds API GET lift %
Hi.
res, code = require('socket.http').request('http://192.168.1.80:40850/api/ABAFA5768F/lights/2/') log(res, code)
If i use the code above, i get this result:
* arg: 1
  * string: {"etag":"9575d92e1a87a4fc7034b5cd188d239c","hascolor":false,"lastannounced":"2021-05-08T20:41:08Z","lastseen":"2021-05-10T14:34Z","manufacturername":"IKEA of Sweden","modelid":"KADRILJ roller blind","name":"Rullegardin Stue venstre","state":{"bri":254,"lift":100,"on":true,"open":false,"reachable":true},"swversion":"2.2.009","type":"Window covering device","uniqueid":"68:0a:e2:ff:fe:4a:74:9a-01"}
* arg: 2
  * number: 200
I want to retract the "lift" value that in this example is "100".
I tried to use the code below to do this, but i can see that there is something missing in the code to be able to extract this value.
if res then   res = require('json').pdecode(res)   if type(res) == 'table' and res.lift then     grp.checkupdate('5/4/80', res.lift)   end end
Kai-Roger
Try res.state.lift
(10.05.2021, 15:23)Daniel. Wrote: Try res.state.lift
Beautiful :)
Kai-Roger
What bridge are you using to control IKEA blinds via API?
(22.05.2021, 15:33)FatMax Wrote: What bridge are you using to control IKEA blinds via API?
Deconz on a RaspberryPi with a Conbee2 USB stick. I`m altso using Deconz for other Zigbee products like many products from Phillips Hue. Very stable solution.
Kai-Roger
