Threads: 29
Hi everyone!
I want to buy this DALI device:
http://www.lunatone.com/produkt/dali-2xc...dimmer-cv/
to dimm Tunable White LEDs strips.
it uses the DT8 protocol. Is it possible to run it with the new pre-release firmware of August?
How?
Cheers!
Elkin
Threads: 43
We don't have ballasts to test new DALI features, but the latest FW has support for raw telegrams which can be used to send any kind of DALI telegram. There's also an updated DALI package in the works which has new commands supported. We can provide it for you if you are willing to test it.
Threads: 29
(08.11.2018, 08:07) admin Wrote: We don't have ballasts to test new DALI features, but the latest FW has support for raw telegrams which can be used to send any kind of DALI telegram. There's also an updated DALI package in the works which has new commands supported. We can provide it for you if you are willing to test it.
OK, will buy the latest ballasts and we can test them together
Threads: 12
28.11.2018, 09:19
(This post was last modified: 28.11.2018, 09:20 by AEK .)
Hi everyone!
i've made tests with Easydim DALI-MIX-DT8 dimmer and its work
you will need to install new dali package (Admin will provide soon)
to set color temp use following script
1 2 3 4 5 6 7 8 9 10 11 12 13 14
require (
'user.dali' )
colortemp =
7000
address =
47
mirek =
math.floor (
1000000 /
colortemp )
dtr0 =
bit.band (
mirek ,
0xFF )
dtr1 =
bit.band (
bit.rshift (
mirek ,
8 ),
0xFF )
dalicmd (
1 ,
'setdtr1' , {
value =
dtr1 })
dalicmd (
1 ,
'setdtr0' , {
value =
dtr0 })
dalicmd (
1 ,
'enabledevicetype' , {
value =
8 })
dalicmd (
1 ,
'setcolortemp' , {
addrtype =
'short' ,
address =
address })
dalicmd (
1 ,
value =
8 })
dalicmd (
1 ,
'activate' , {
addrtype =
'short' ,
address =
address })
to make light warmer use this
require (
'user.dali' )
dalicmd (
1 ,
value =
8 })
dalicmd (
1 ,
'colortempwarmer' , {
addrtype =
'short' ,
address =
47 })
cooler
require (
'user.dali' )
dalicmd (
1 ,
value =
8 })
dalicmd (
1 ,
'colortempcooler' , {
addrtype =
'short' ,
address =
47 })
Threads: 28
Which DT8 control type did you use? As far I remember there are:
- color temperature in Kelvin
- XY coordinate
- RGBW
I'm guessing it is the color temperature.
Threads: 12
(28.11.2018, 10:12) Daniel. Wrote: Hi
- XY coordinate
- RGBW
this dimmer has cold white and warm white output only. so I use only temp color comands
I have another device DALI-ST-DT8 (RGBW dimmer) and I will try other comands with it.
before this I will try to set color limits
Threads: 0
19.12.2018, 12:16
(This post was last modified: 19.12.2018, 12:17 by Snoolik .)
Some functions for Type 8 temperature control
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185
function getCurrentTc (
gateway ,
addr )
code =
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
if err then return nil ,
'setdtr0 error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
'enabledevicetype error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
'querycolorvalue' , {
addrtype =
'short' ,
address =
addr })
'querycolorvalue error: ' ..
err end
hb =
res :
byte ()
res ,
err =
dalicmd (
gateway ,
'querydtr0' , {
addrtype =
'short' ,
address =
addr })
'querydtr0 error: ' ..
err end
lb =
res :
byte ()
mirek =
bit.lshift (
hb ,
8 ) +
lb
tc =
1000000 /
mirek
return tc
function getCoolestTcLimit (
gateway ,
addr )
code =
128
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
hb =
res :
byte ()
res ,
err =
dalicmd (
gateway ,
'querydtr0' , {
addrtype =
'short' ,
address =
addr })
err end
lb =
res :
byte ()
mirek =
bit.lshift (
hb ,
8 ) +
lb
tc =
1000000 /
mirek
return tc
function getCoolestTcLimitPhys (
gateway ,
addr )
code =
129
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
hb =
res :
byte ()
res ,
err =
dalicmd (
gateway ,
'querydtr0' , {
addrtype =
'short' ,
address =
addr })
err end
lb =
res :
byte ()
mirek =
bit.lshift (
hb ,
8 ) +
lb
tc =
1000000 /
mirek
return tc
function getWarmestTcLimit (
gateway ,
addr )
code =
130
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
hb =
res :
byte ()
res ,
err =
dalicmd (
gateway ,
'querydtr0' , {
addrtype =
'short' ,
address =
addr })
err end
lb =
res :
byte ()
mirek =
bit.lshift (
hb ,
8 ) +
lb
tc =
1000000 /
mirek
return tc
function getWarmestTcLimitPhys (
gateway ,
addr )
code =
131
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
hb =
res :
byte ()
res ,
err =
dalicmd (
gateway ,
'querydtr0' , {
addrtype =
'short' ,
address =
addr })
err end
lb =
res :
byte ()
mirek =
bit.lshift (
hb ,
8 ) +
lb
tc =
1000000 /
mirek
return tc
function setWarmestTcLimit (
gateway ,
addr ,
tc )
code =
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
'setdtr2 error: ' ..
err end
mirek =
math.floor (
1000000 /
tc )
dtr0 =
bit.band (
mirek ,
0xff )
dtr1 =
bit.rshift (
bit.band (
mirek ,
0xff00 ),
8 )
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
dtr0 })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
dtr1 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'storecolortemplimit' , {
addrtype =
'short' ,
address =
addr })
'storecolortemplimit error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
return res ,
err
function setCoolestTcLimit (
gateway ,
addr ,
tc )
code =
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
err end
mirek =
math.floor (
1000000 /
tc )
dtr0 =
bit.band (
mirek ,
0xff )
dtr1 =
bit.rshift (
bit.band (
mirek ,
0xff00 ),
8 )
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
dtr0 })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
dtr1 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
return res ,
err
function saveSceneTc (
gateway ,
addr ,
tc ,
arc_level ,
scene )
mirek =
math.floor (
1000000 /
tc )
dtr0 =
bit.band (
mirek ,
0xff )
dtr1 =
bit.rshift (
bit.band (
mirek ,
0xff00 ),
8 )
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
dtr1 })
'setdtr1 tc error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
dtr0 })
'setdtr0 tc error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'setcolortemp' , {
addrtype =
'short' ,
address =
addr })
'setcolortemp error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
arc_level })
'setdtr0 arc_level error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
'storescene' , {
addrtype =
'short' ,
address =
addr ,
value =
scene })
'storescene error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
'storescene' , {
addrtype =
'short' ,
address =
addr ,
value =
scene })
err end
return res ,
err
function getSupportedColorTypeFeatures (
gateway ,
addr )
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'querycolorfeatures' , {
addrtype =
'short' ,
address =
addr })
'querycolorfeatures error: ' ..
err end
res =
res :
byte ()
xy =
bit.band (
res ,
0x01 )
tc =
bit.rshift (
bit.band (
res ,
0x02 ),
1 )
direct =
bit.rshift (
bit.band (
res ,
0x1c ),
2 )
rgbwaf =
bit.rshift (
bit.band (
res ,
0xe0 ),
5 )
return xy ,
tc ,
direct ,
rgbwaf
function getSceneTc (
gateway ,
addr ,
scene )
res ,
err =
dalicmd (
gateway ,
'queryscene' , {
addrtype =
'short' ,
address =
addr ,
value =
scene })
'queryscene error: ' ..
err end
arc_level =
res :
byte ()
code =
226
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
hb =
res :
byte ()
res ,
err =
dalicmd (
gateway ,
'querydtr0' , {
addrtype =
'short' ,
address =
addr })
err end
lb =
res :
byte ()
mirek =
bit.lshift (
hb ,
8 ) +
lb
tc =
1000000 /
mirek
return arc_level ,
tc
Threads: 0
26.12.2018, 12:22
(This post was last modified: 10.01.2020, 07:26 by Snoolik .)
Function for RGBW/RGBWAF Type 8 dimmer
function setRGBWAF (
gateway ,
addr ,
r ,
g ,
b ,
w ,
a ,
f )
if r ==
nil then r =
0 end
if g ==
nil then g =
0 end
if b ==
nil then b =
0 end
if w ==
nil then w =
0 end
if a ==
nil then a =
0 end
if f ==
nil then f =
0 end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
r ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
g ,
254 ) })
'setdtr1 error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
b ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'setrgbdimlevel' , {
addrtype =
'short' ,
address =
addr })
'setrgbdimlevel error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
w ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
a ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
f ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'setwafdimlevel' , {
addrtype =
'short' ,
address =
addr })
'setwafdimlevel error: ' ..
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'activate' , {
addrtype =
'short' ,
address =
addr })
return res ,
err
function saveSceneRGBWAF (
gateway ,
addr ,
scene ,
arc_level ,
r ,
g ,
b ,
w ,
a ,
f )
if r ==
nil then r =
0 end
if g ==
nil then g =
0 end
if b ==
nil then b =
0 end
if w ==
nil then w =
0 end
if a ==
nil then a =
0 end
if f ==
nil then f =
0 end
if arc_level ==
nil then arc_level =
254 end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
r ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
g ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
b ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
w ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
a ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
f ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
arc_level })
err end
res ,
err =
dalicmd (
gateway ,
'storescene' , {
addrtype =
'short' ,
address =
addr ,
value =
scene })
err end
res ,
err =
dalicmd (
gateway ,
'storescene' , {
addrtype =
'short' ,
address =
addr ,
value =
scene })
return res ,
err
Threads: 0
Functions to get current RGBWAF:
function getChannel (
gateway ,
addr ,
code )
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
code })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
return res ,
err
function getRGBWAF (
gateway ,
addr )
res_t = {}
for i =
233 ,
237 ,
1 do
res ,
err =
getChannel (
gateway ,
addr ,
i )
if res then table.insert (
res_t ,
res :
byte ())
return res_t
Threads: 75
(26.12.2018, 12:22) Snoolik Wrote: Function for RGBW/RGBWAF Type 8 dimmer
gateway ,
addr ,
r ,
g ,
b ,
w ,
a ,
f )
if r ==
nil then r =
0 end
if g ==
nil then g =
0 end
if b ==
nil then b =
0 end
if w ==
nil then w =
0 end
if a ==
nil then a =
0 end
if f ==
nil then f =
0 end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
r ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
g ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
b ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
w ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
a ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
f ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'activate' , {
addrtype =
'short' ,
address =
addr })
return res ,
err
gateway ,
addr ,
scene ,
arc_level ,
r ,
g ,
b ,
w ,
a ,
f )
if r ==
nil then r =
0 end
if g ==
nil then g =
0 end
if b ==
nil then b =
0 end
if w ==
nil then w =
0 end
if a ==
nil then a =
0 end
if f ==
nil then f =
0 end
if arc_level ==
254 end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
r ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
g ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
b ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
w ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
a ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
f ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
arc_level })
err end
res ,
err =
dalicmd (
gateway ,
'storescene' , {
addrtype =
'short' ,
address =
addr ,
value =
scene })
err end
res ,
err =
dalicmd (
gateway ,
'storescene' , {
addrtype =
'short' ,
address =
addr ,
value =
scene })
return res ,
err
Hello and thanks for your efforts.
first in the setRGBWAF function what are (
gateway, addr ), and how to convert the 251.600 6 byte DALI RGBW data type to fit the function (r,g,b,w,a,f)
regards,
Best Regards,
Threads: 43
Use this, change gateway number and short address as needed:
gateway =
'internal'
addr =
12
require (
'user.dali' )
value =
event.getvalue ()
gateway ,
addr ,
r ,
g ,
b ,
w ,
a ,
f )
if r ==
nil then r =
0 end
if g ==
nil then g =
0 end
if b ==
nil then b =
0 end
if w ==
nil then w =
0 end
if a ==
nil then a =
0 end
if f ==
nil then f =
0 end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
r ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
g ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
b ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
w ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
a ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
f ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'activate' , {
addrtype =
'short' ,
address =
addr })
return res ,
err
setRGBWAF (
gateway ,
addr ,
value.red ,
value.green ,
value.blue ,
value.white )
Threads: 75
06.07.2021, 11:25
(This post was last modified: 06.07.2021, 11:28 by khalil .)
(06.07.2021, 10:58) admin Wrote: Use this, change gateway number and short address as needed:
gateway =
'internal'
addr =
12
require (
'user.dali' )
value =
event.getvalue ()
gateway ,
addr ,
r ,
g ,
b ,
w ,
a ,
f )
if r ==
nil then r =
0 end
if g ==
nil then g =
0 end
if b ==
nil then b =
0 end
if w ==
nil then w =
0 end
if a ==
nil then a =
0 end
if f ==
nil then f =
0 end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
r ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
g ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
b ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr0' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
w ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr1' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
a ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
'setdtr2' , {
addrtype =
'short' ,
address =
addr ,
value =
math.min (
f ,
254 ) })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr })
err end
res ,
err =
dalicmd (
gateway ,
addrtype =
'short' ,
address =
addr ,
value =
8 })
err end
res ,
err =
dalicmd (
gateway ,
'activate' , {
addrtype =
'short' ,
address =
addr })
return res ,
err
setRGBWAF (
gateway ,
addr ,
value.red ,
value.green ,
value.blue ,
value.white )
thank you, admin
Great
can I read the RGBW Status?
Best Regards,
Threads: 43
Threads: 75
07.07.2021, 14:37
(This post was last modified: 07.07.2021, 14:39 by khalil .)
(06.07.2021, 11:35) admin Wrote: See this example: https://forum.logicmachine.net/showthrea...2#pid12902
thank you admin for your great help and effort.
I do it like this and its wok
if you have any comments
RgbwSts = getRGBWAF(gateway, addr)
WriteValue = {}
WriteValue["red"] = RgbwSts[1]
WriteValue["white"] = RgbwSts[4]
WriteValue["blue"] = RgbwSts[3]
WriteValue["green"] = RgbwSts[2]
Also, I need the feedback for the on/off object and scale(0-100%)
regards,
Best Regards,
Threads: 43
Threads: 75
(07.07.2021, 14:39) admin Wrote: See this: https://forum.logicmachine.net/showthrea...8#pid19988
thank you, admin
What is the right way to control a group of DALI Lights/short addresses at the same time?
Best Regards,
Threads: 43
See this:
https://forum.logicmachine.net/showthread.php?tid=133
I also recommend looking into our CANx-DALI gateway. It provides most of the features you need via UI instead of scripts.
Threads: 75
(08.07.2021, 10:57) admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=133
Thank you, admin
I will, but for this project, we already bought the products and give a price for the customer, unfortunately we didn't test everything before
Best Regards,
