how to Check email
hello
I have a user who asked to receive alarms by email and everything was alright and an email was sent.
after they add a firewall, I can access the remote via ETS, and the email stops sending!
is there a way to check that its a firewall issue
I am using SL V2.6.1
regards,
Best Regards,
Try running this script, change server and port accordingly to yours.
function checktcp(ip, port)   local sock = require('socket').tcp()   sock:settimeout(1)   local res, err = sock:connect(ip, port)   sock:close()   return res, err end -- change IP/PORT as needed res, err = checktcp('smtp.gmail.com', 465) if res then   log('connect OK') else   log('connect ERROR', err) end
(24.08.2021, 13:20)Daniel. Wrote: Try running this script, change server and port accordingly to yours.
thanks, Daniel
I got this in the log:
* arg: 1
  * string: connect ERROR
* arg: 2
  * string: Host is unreachable
so its firewall issue
Best Regards,
It looks like yes
