Script help
Could you please help me with one resident script?
If the temperature is below "A" for more then "B" seconds/ minutes turn on 1/1/2. If the temperature is above C for more then "D" seconds/minutes turn off 1/1/2
We have temperature with address 1/1/1.
Modify as needed, make sure that step value is the same as script sleep time (at least 5 seconds, can be more if the wait time is larger).
1234567891011121314151617181920212223242526272829303132333435363738394041
temp = grp.getvalue('1/1/1') -- temp limits temp_low = 20 temp_high = 30 -- time in seconds time_low = 20 time_high = 40 step = 5 -- script sleep time in seconds if temp < temp_low then   timer_high = nil   if timer_low then     if timer_low < time_low then       timer_low = timer_low + step       if timer_low >= time_low then         grp.write('1/1/2', true)       end     end   else     timer_low = 0   end elseif temp > temp_high then   timer_low = nil   if timer_high then     if timer_high < time_high then       timer_high = timer_high + step       if timer_high >= time_high then         grp.write('1/1/2', false)       end     end   else     timer_high = 0   end end
(20.09.2021, 10:52)admin Wrote: Modify as needed, make sure that step value is the same as script sleep time (at least 5 seconds, can be more if the wait time is larger).
Thank you very much!
