Threads: 11
is it possible to create a thermostat PI (e.g. MTN6212-04XX) with Wiser?
I don't mean to have an MTN6212-04XX in the installation and just to visualize through Wiser.
In fact, I need to replace the MTN6212-04XX with a script.
Thanks for your help!
Threads: 11
In this link mentions that: There is a PID function already added by default in Logic Machine -> Scripts -> Tools menu.
I have Wiser and not Logic Machine and there isn't by default in Wiser.
Threads: 11
I will check it.
Thanks for the help.
Appreciated.
Threads: 11
Can you please tell me what should I write to the residential script?
Thanks in advance.
Threads: 43
See my previous post. The code there is for the resident script. Set the script sleep interval to at least 10 seconds or more. This controls how often the algorithm runs. Change group addresses as needed.
Threads: 43
Check that 32/2/16 exists and has correct data type. Try restarting the script by performing disable/enable.
