07.10.2021, 18:11
Hello, is there a code of some sort that enables me to write from LM to a bacnet object on another device? For instance a HVAC unit.
Bacnet client mapping
07.10.2021, 18:11
08.10.2021, 07:13
I assume you are asking for BACnet client solution. There is app in the store for this or you can use script https://openrb.com/logicmachine-as-bacnet-client/
This implementation is only for small amount of objects. Anything bigger will struggle.
11.10.2021, 07:48
(08.10.2021, 07:13)Daniel Wrote: I assume you are asking for BACnet client solution. There is app in the store for this or you can use script https://openrb.com/logicmachine-as-bacnet-client/ Thank you. LM will be able to work as bot client and server? What do You define as small amount of objects? 10 or 100? Just as a hint.
11.10.2021, 07:55
To run both at the same time you must change BACnet port in server. Both cant run on same network. It is around 50 objects.
11.10.2021, 09:16
