13.05.2021, 06:07
Is it possible to use a script to change the active state of another script?
I tried the following code, however it doesn't seem to change the active state / icon in the script list view. (I'm running a Schneider SHAC with the older logic machine firmware which might be the problem)
I successfully run the following the following code which directly interacts with the database to change the status of schedules - is something similar required to activate / deactivate scripts?
Many thanks in advance
Kind Regards
James
-- Change active status of script
function enableScript(scriptname, active)
if active == true then
script.enable('scriptname')
log('Script "' .. scriptname .. '" is active')
script.disable('scriptname')
log('Script "' .. scriptname .. '" is disabled')
endI successfully run the following the following code which directly interacts with the database to change the status of schedules - is something similar required to activate / deactivate scripts?
-- Change active status of schedule
function enableSchedule(schedulername, active)
query = 'SELECT * FROM schedulers'
for _, scheduler in ipairs(db:getall(query)) do
if scheduler.name == schedulername then
db:update('schedulers', { active = 1 }, { id = scheduler.id })
log('Schedule "' .. schedulername .. '" is active')
db:update('schedulers', { active = 0 }, { id = scheduler.id })
log('Schedule "' .. schedulername .. '" is disabled')
-- Clear old schedules after updating enable state in database with enableSchedule
function updateSchedulers()
local files = io.ls('/tmp')
for _, file in ipairs(files) do
if file:find('lm-scheduler-', 1, true) then
os.remove('/tmp/' .. file)
endMany thanks in advance
Kind Regards
James
