Modbus uint32
Hello. When reading a HoldingReg with datatype uint32 from "readtest" I get this respond as attached image. But when integratin via JSON and datatype "12" I get a large number.. tried different datatypes, with no change.. any ideas what to try?
did you set "datatype": "uint32" ?
(13.12.2021, 12:53)Daniel Wrote: did you set  "datatype": "uint32" ?
yes.
{"bus_datatype":"uint32","bus_address":"4/2/12","address":43418,"value_nan":[65472,0],"type":"register","read_count": 1,"value_multiplier":1,"units":"h","name":"15EP_OP","datatype":"uint32"},
{"bus_datatype":"uint32","bus_address":"4/2/6","address":43420,"value_nan":[65472,0],"type":"register","read_count": 1,"value_multiplier":1,"units":"h","name":"14EP_OP","datatype":"uint32"},
Remove read_count": 1
(13.12.2021, 13:14)Daniel Wrote: Remove read_count": 1
still same result..
Are you sure that address is correct? "address":43418, in the image it is 3418
