Looking for some help to determine if a particular light/group address was last turned on via a physical switch, or via a PIR motion sensor (which is a different address).
I need the switch to 'Win' i.e if a user turned on a light via a switch, leave it on when the PIR motion even expires. Is this possible?
This is a C-bus system not KNX, but more or less the same in terms of principles and addresses...
The real lighting GA is assigned to a bus relay output, and also to 4 physical buttons over various switch plates. Each button has a local LED and works great to indicate the state of the actual light, so I don't want to interfere with this.
The PIR is a normal dumb/electrical device (non-bus aware itself) but is connected via a volt-free bus-auxiliary input, and effectively works like a bell-push event as seen by the logic machine / SHAC. It's simply Motion = 1, No motion = 0. The length of time the PIR signal stays at 1 (motion detected) is determined via a mechanical dial on the PIR itself, can't be influenced via LM...
I have this basic construct of what I need to do, but I'm missing the magic of determining what the last device to turn the light on really was...
Any help is greatly appreciated.
-- Control of main GA via a PIR Slave GA
local Master = 35     -- Utility Room Light Group Address (all existing switch buttons use this Group)
local Slave = 73    -- PIR Group Address (This event script is linked to this address)
local Nw = 0
local Group = 56
value = event.getvalue()
--if light is currently off, turn it on
if (GetCBusLevel (Nw,Group,Master) = 0) and (value >=1) -- Similar to standard grp.getvalue in standard LM...
then
  --set Master GA On
  SetCBusState(Nw, Group, Master, true)    -- Similar to standard grp.write in standard LM..
--PIR Goes off - if light is currently on, and was turned on via motion sensor and not a switch, turn it off
if (GetCBusLevel (Nw,Group,Master) >= 1) and (value = 0)
  -- Here I would like to determine somehow if light/GA was turned on via a physical button, or the PIR
  -- The physical switch should 'win' - if a person turned on light manually via a button, leave it on.
then
  --set Master GA Off
  SetCBusState(Nw, Group, Master, false)
 ... If this was like an industrial PLC I'd use some Set/Reset blocks and some rising and falling edge triggers...just struggling to adopt this approach to LUA code..I'll keep at it, but thanks for the suggestion
