Hi all,
I'm migrating from my old LM2 to a new LM5. I have created a backup from the LM2 and restored on the LM5. The restore went ok for all scripts and other elements but my trend logs are completely empty. I understood that normally these are part of the backup but in my case it looks like they aren't.
I have found on the forum scripts to export the logs and sent them via email (and cvs attachment). Is there a way how I could import them into the LM5? Any other easy way to copy them from the LM2 to the LM5?
[update] - if trigger a new value that is being trend recorded then somehow the graph is showing in the trendlog. However, not the full data set. E.g. I log my temperature since 2013. On the old LM2 i can go back to 2013 without any issue. On the LM5, I only can go back to Dec 2019. All timestamps before are empty on the LM5. The trend log is configured to keep monthly data for 10years, hence I would expect also the older data to be available.
Any guidance is appreciated !
regards
Joost
regards
Joost
