Change Active Status of a Script
Is it possible to use a script to change the active state of another script?
I tried the following code, however it doesn't seem to change the active state / icon in the script list view. (I'm running a Schneider SHAC with the older logic machine firmware which might be the problem)
-- Change active status of script function enableScript(scriptname, active)     if active == true then    script.enable('scriptname')    log('Script "' .. scriptname .. '" is active')   else    script.disable('scriptname')     log('Script "' .. scriptname .. '" is disabled')   end   end
I successfully run the following the following code which directly interacts with the database to change the status of schedules - is something similar required to activate / deactivate scripts?
123456789101112131415161718192021222324252627
-- Change active status of schedule function enableSchedule(schedulername, active)     query = 'SELECT * FROM schedulers'   for _, scheduler in ipairs(db:getall(query)) do     if scheduler.name == schedulername then       if active == true then         db:update('schedulers', { active = 1 }, { id = scheduler.id })         log('Schedule "' .. schedulername .. '" is active')       else         db:update('schedulers', { active = 0 }, { id = scheduler.id })         log('Schedule "' .. schedulername .. '" is disabled')       end     end   end     end  -- Clear old schedules after updating enable state in database with enableSchedule function updateSchedulers()   local files = io.ls('/tmp')   for _, file in ipairs(files) do     if file:find('lm-scheduler-', 1, true) then       os.remove('/tmp/' .. file)     end   end end
Many thanks in advance
Kind Regards
James
Does the correct status show up after the page reload? Periodical script status reload (every 6 seconds) has been implemented for some time already.
Unfortunately no, the refresh doesn't seem to make a difference (even after 30 secs).
I'm referring to the scripts by name (ie: 'Tesla Powerwall - Auto Set Reserved Percentage') - is this ok or should I be using an ID or something different?
is there an alternative way to change the status with the old firmware by directly updating the database.
Or is there a way I can test if the script.disable() is supported on my firmware?
Kind Regards
James
Changing the DB value won't help because the script itself will not be stopped or started.
See what the enable/disable call returns. If script is found then enable returns true, disable returns false. Otherwise you will get nil + error message.
res, err = script.enable('SCRIPT NAME HERE') log(res, err)
Here is the output of the your test code - it's working
TEST 13.05.2021 18:43:24 * arg: 1   * bool: true * arg: 2   * nil
I found the error in my earlier code too .. working function below
-- Change active status of script function enableScript(scriptname, active)     if active == true then    script.enable(scriptname)    log('Script "' .. scriptname .. '" is active')   else    script.disable(scriptname)     log('Script "' .. scriptname .. '" is disabled')   end   end
Many thanks
Kind Regards
James
(13.05.2021, 08:46)jamesng Wrote: Hi
Many thanks
Kind Regards
James
Im just a beginner, but i hope you will help me.
I will activate and disable a 'Resident script' depending on a feedback object of a output.
the group object is 1/4/53 (bedroom [fb])
when this object is true i will run a script to activate the 'Resident script' called 'bedroom [fb], turn off'
and the same but turn it off by the same group adress
when this object is false i will run a script to disable the 'Resident script' called 'bedroom [fb], turn off'
I saw you will do the same, but i dont know how to use this script.
Simply create an event script attached to a 1-bit boolean object and put this into the editor.
enable = event.getvalue() script.set('bedroom [fb], turn off', enable)
(12.10.2021, 12:22)admin Wrote: Simply create an event script attached to a 1-bit boolean object and put this into the editor.
WoW thanks, so fast i wish i was good as you are  Heart
just another question, just curious, what is the different between the 2 scripts.
or what does do the other script of Topic Starter?
I tried to enable and disable a resident PID script with a event script on a virtual object but i can't get it to work.
enable = event.getvalue('32/1/59') script.set('PID, turn off', enable)
Your resident script probably is not called "PID, turn off". Also the group address is not needed for event.getvalue().
(21.01.2022, 22:46)KoBra Wrote: I tried to enable and disable a resident PID script with a event script on a virtual object but i can't get it to work.
Thanks, that was the only combination i didn't test.
