Threads: 97
Has anyone already made any code for the Philips Hue api V2?
Why the v2 api? because i want to trigger dynamic scenes and thats not possible in the v1 api.
Please correct my code is you see improvements.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
https =
require (
'ssl.https' )
ltn12 =
require (
'ltn12' )
json =
require (
'json' )
local bridge =
'ip of the bridge'
local usr =
'same user as api v1'
function hueExec (
iMethod ,
iCommand ,
iBody )
resp = {}
body =
json.encode (
iBody )
res ,
code ,
headers =
https.request ({
url =
'https://' ..
bridge.. '/clip/v2/resource' ..
iCommand ,
method =
iMethod ,
source =
ltn12.source.string (
body ),
sink =
ltn12.sink.table (
resp ),
headers = { [
'hue-application-key' ] =
usr ,
'Content-Type' ] =
'application/json' ,
'Accept' ] =
'Content-Length' ] = #
body
if not res or code ~=
200 then
return
resp =
table.concat (
resp )
resp =
json.pdecode (
resp )
return resp
function getLights ()
return hueExec (
'GET' ,
'/light' )
function getLight (
iLight )
return hueExec (
'GET' ,
'/light/' ..
iLight )
function runScene (
iScene ,
iAction )
vAction =
iAction or 'active'
hueExec (
'PUT' ,
'/scene/' ..
iScene , {
recall = {
action =
vAction }})
Threads: 97
02.02.2022, 14:53
(This post was last modified: 02.02.2022, 14:54 by gjniewenhuijse .)
Can anyone help me to setup an evenstream connection?
Migration Guide to the new Hue API - Philips Hue Developer Program (meethue.com)
The V2 API supports proactive notifications on changes through Server-Sent Events (SSE) under the /eventstream endpoint:
curl --insecure -N -H 'hue-application-key: <appkey>' -H 'Accept: text/event-stream' https://<ipaddress>/eventstream/clip/v2
Events have an id, timestamp, type (‘update’, ‘add’, ‘delete’, ‘error’), and data field which contains the changed properties of the resource in the same format as a GET response on the same resource type. The following is an example event stream that would result from turning a light on and off:
data: [{"creationtime":"2021-04-02T00:15:04Z","data":[{"id":"4413c8fd-6643-48b5-ad02-59453edf8a61","id_v1":"/lights/1","on":{"on":true},"type":"light"}],"id":"19845c30-2e4c-4205-a7b4-8bd496f3407d","type":"update"}]
data: [{"creationtime":"2021-04-02T00:15:05Z","data":[{"id":"4413c8fd-6643-48b5-ad02-59453edf8a61","id_v1":"/lights/1","on":{"on":false},"type":"light"}],"id":"bea68344-a36c-4bfd-a658-97830e4e2b1a","type":"update"}]
On HTTP1.1, you will need a separate connection for the SSE request and regular requests, but we recommend using HTTP2 to multiplex them over a single connection which is more resource efficient.
Currently there is a 1 second rate limit on the amount of event containers the Bridge will send. If the same property has changed twice within that timeframe, you only get the last state. If multiple resources have changed within that timeframe, you will get multiple events grouped in a single container.
Threads: 43
You can adapt this code for your use case:
https://forum.logicmachine.net/showthrea...1#pid15941
Add headers to initial request lines and change APPKEY to the actual application key:
sock :
send (
'GET ' ..
path ..
' HTTP/1.1\r\n' ..
'Host: ' ..
host ..
'\r\n' ..
'Accept: text/event-stream\r\n' ..
'hue-application-key: APPKEY\r\n' ..
'\r\n'
Threads: 97
(02.02.2022, 15:53) admin Wrote: You can adapt this code for your use case: https://forum.logicmachine.net/showthrea...1#pid15941
sock :
send (
'GET ' ..
path ..
' HTTP/1.1\r\n' ..
'Host: ' ..
host ..
'\r\n' ..
'\r\n'
i think i do something wrong because the output of the lines is the same as the bridge html source what i see in the browser
if not sock then
host =
'my bridge ip'
port =
80
path =
'/eventstream/clip/v2'
appkey =
'mysecretappkey'
sock =
require (
'socket' ).
tcp ()
sock :
settimeout (
10 )
res ,
err =
sock :
connect (
host ,
port )
if res then
sock :
send (
'GET ' ..
path ..
' HTTP/1.1\r\n' ..
'Host: ' ..
host ..
'\r\n' ..
'hue-application-key: ' ..
appkey ..
'\r\n' ..
'\r\n'
log (
'connect failed: ' ..
tostring (
err ))
sock :
close ()
line ,
err =
sock :
receive ()
if line then
log (
'line: ' ..
line )
log (
'receive failed: ' ..
tostring (
err ))
sock :
close ()
sock =
nil
Threads: 43
Maybe some extra headers are needed. What do you get in the output?
Threads: 97
03.02.2022, 09:11
(This post was last modified: 03.02.2022, 09:14 by gjniewenhuijse .)
(03.02.2022, 07:21) admin Wrote: Maybe some extra headers are needed. What do you get in the output?
same url in the browser
Threads: 43
It can return 404 if the appkey is incorrect.
Threads: 97
03.02.2022, 09:34
(This post was last modified: 03.02.2022, 09:45 by gjniewenhuijse .)
(03.02.2022, 09:22) admin Wrote: It can return 404 if the appkey is incorrect.
but its the same appkey as i use for the normal connection from the other example. And there it works.
with curl the code is:
I see https.. Do the example also setup a https connection? and is this to port 80 or 443?
Threads: 43
Does it work for you with curl? HTTPS is 443 but some extra code is needed for the raw socket to use encryption:
https://forum.logicmachine.net/showthrea...903#pid903
Threads: 97
03.02.2022, 10:12
(This post was last modified: 03.02.2022, 10:44 by gjniewenhuijse .)
(03.02.2022, 09:50) admin Wrote: Does it work for you with curl? HTTPS is 443 but some extra code is needed for the raw socket to use encryption: https://forum.logicmachine.net/showthrea...903#pid903
yep, curl for windows code works:
curl --insecure -N -H "hue-application-key: sameapiuserasbefore" -H "Accept: text/event-stream"
https://myipaddress/eventstream/clip/v2
and thx, the raw socket example works also.
working code for evenstream
if not sock then
host =
'fillyourip'
port =
443
proto =
'tlsv12'
path =
appkey =
'fillyouruser'
require (
'ssl' )
sock =
require (
'socket' ).
tcp ()
sock :
settimeout (
10 )
res ,
err =
sock :
connect (
host ,
port )
if res then
sock =
ssl.wrap (
sock ,
proto )
res ,
err =
sock :
dohandshake ()
if res then
sock :
send (
'GET ' ..
path ..
' HTTP/1.1\r\n' ..
'Host: ' ..
host ..
'\r\n' ..
appkey ..
'\r\n' ..
'\r\n'
log (
'handshake failed: ' ..
tostring (
err ))
log (
tostring (
err ))
sock :
close ()
line ,
err =
sock :
receive ()
if line then
if line :
find (
': hi' )
then
log (
'connection ok: ' ,
line )
elseif line :
find (
'data:' )
then
log (
'data' ,
line )
log (
tostring (
err ))
sock :
close ()
sock =
nil
Threads: 97
parsing the output is another thing:
line output: data: [{"creationtime":"2022-02-03T13:35:32Z","data":[{"id":"f2ef58b3-818e-45ea-a291-325e8eeb97bc","id_v1":"/lights/10","on":{"on":false},"owner":{"rid":"0120cec8-b58e-4206-a409-2bd99055af55","rtype":"device"},"type":"light"}],"id":"49142b93-3da7-49dc-9ad6-10809df8fe9d","type":"update"}]
line =
string.sub (
line ,
8 ,-
2 )
line =
json.pdecode (
line )
This works
But the second output combines more lines, how to decode this line?
line output:
data: [{"creationtime":"2022-02-03T13:35:32Z","data":[{"id":"728be63c-dc61-42b1-9a84-54daeff76046","id_v1":"/groups/0","on":{"on":false},"type":"grouped_light"}],"id":"b201d09a-0ab2-4a60-b72f-3a099841ebbc","type":"update"},{"creationtime":"2022-02-03T13:35:32Z","data":[{"id":"33b4f136-c59e-4270-83af-814c4f5ba856","id_v1":"/groups/18","on":{"on":false},"type":"grouped_light"}],"id":"e2860e1b-ebd0-40b0-81ed-f1c0b27163a3","type":"update"},{"creationtime":"2022-02-03T13:35:32Z","data":[{"id":"7a8f900c-c312-403a-bf73-9d2fcb005489","id_v1":"/groups/19","on":{"on":false},"type":"grouped_light"}],"id":"1cc814e9-9210-4e75-92c0-29a543c32dcb","type":"update"}]
Threads: 15
10.01.2023, 09:16
(This post was last modified: 10.01.2023, 09:21 by Joep .)
I would like to contribute on this and started with the Hue discovey by changing the script i found from
https://forum.logicmachine.net/showthrea...4#pid24214
Below the modified version that gives all the Hue Bridge information with most important the IP address.
1 2 3 4 5 6 7 8 9
hue =
io.readproc (
'avahi-browse _hue._tcp' )
lines =
hue :
split (
'\n' )
for _ ,
line in ipairs (
lines )
do
ip ,
port ,
name ,
descr =
unpack (
line :
split (
'\t' ))
if descr then
log (
ip ,
port ,
name ,
descr )
Threads: 7
Hi @gjniewenhuijse,
Have you been able to make any progress on using api V2? like you, I need to use dynamic scenes and motion sensors.
thanks you
Threads: 97
(04.11.2024, 14:17) Fcs Wrote: Hi @gjniewenhuijse,
thanks you
I made some code to use the api v2
function hueExec (
iMethod ,
iCommand ,
iBody )
https =
require (
'ssl.https' )
ltn12 =
require (
'ltn12' )
json =
require (
'json' )
resp = {}
body =
json.encode (
iBody )
res ,
code ,
headers =
https.request ({
url =
'https://' ..
iCommand ,
method =
iMethod ,
source =
body ),
sink =
ltn12.sink.table (
resp ),
headers = { [
usr ,
'Content-Type' ] =
'Accept' ] =
body
200 then
return res ,
code
return json.pdecode (
table.concat (
resp ))
return hueExec (
'GET' ,
'/light' )
function getLight (
iLight )
return hueExec (
'GET' ,
'/light/' ..
iLight )
function runScene (
iScene ,
iAction )
vAction =
iAction or 'active'
hueExec (
'PUT' ,
'/scene/' ..
iScene , {
recall = {
action =
vAction }})
and tested with the event handler
json =
require (
'json' )
if not sock then
host =
'x.x.x.x'
port =
443
proto =
'tlsv12'
path =
appkey =
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
require (
'ssl' )
sock =
require (
'socket' ).
tcp ()
sock :
settimeout (
10 )
res ,
err =
sock :
connect (
host ,
port )
if res then
sock =
ssl.wrap (
sock ,
proto )
res ,
err =
sock :
dohandshake ()
if res then
sock :
send (
'GET ' ..
path ..
' HTTP/1.1\r\n' ..
'Host: ' ..
host ..
'\r\n' ..
appkey ..
'\r\n' ..
'\r\n'
log (
tostring (
err ))
log (
tostring (
err ))
sock :
close ()
line ,
err =
sock :
receive ()
if line then
log (
'line: ' ..
line )
if line :
find (
': hi' )
then
log (
'connection ok: ' ,
line )
elseif line :
find (
'data:' )
then
line =
'{"data": ' ..
string.sub (
line ,
7 )..
log (
'textline' ,
line )
line =
json.pdecode (
line )
log (
line.data )
for _l ,
l_items in pairs (
line.data )
do
log (
l_items )
log (
l_items.type ,
l_items.data [
1 ].
id_v1 ,
l_items.data [
1 ].
on.on )
log (
tostring (
err ))
sock :
close ()
sock =
nil
