PowerView Blind Control
I have a top-down/bottom-up blind that can be controlled with a hub named PowerView. Firstly, I tried to control it with relays since, in my opinion, it is better than a wireless connection, but unfortunately, I had some problems, so I started to control it with API through the PowerView hub. I am able to control it, but I have the problem that I am using a slide control from a touch panel to set the blind position. I use an event script, and each time I slide the slider a bit, it sends an event, which results in the blind moving in many smaller steps. I would like to only have one event, which then waits 2 seconds before it reads the target position for the blind.
Event from slider:
require('user.Blind_TopDownBottomUp') require('sem') -- group address or name addr = '0/2/7' ShadeID = '63686' semaphore = sem.open('eventlock') timeout = 5 * 10 -- wait for unlock or 5 second timeout while not semaphore:trywait() and timeout > 0 do   sleep(0.1)   timeout = timeout - 1 end -- perform script actions Blind(ShadeID, addr) -- unlock semaphore semaphore:post()
Blind function:
-- blind (Top-down/Bottom-up) function Blind(ShadeID, addr)   require('ltn12')   require('json')     http = require('socket.http')     local Bridge = '192.168.1.50'   -- Blind Position     Pos = grp.getvalue(addr)     BlindPos = tostring(math.floor(Pos*655.35));         url = 'http://' .. Bridge .. '/api/shades'       res, code, headers, status = http.request(url)       -- position1 is the bottom rail and it is 0 at the bottom and 65535 at the top   -- position2 is the top rail and it is 65535 at the bottom and 0 at the top   body = '{"shade":{"positions":{"posKind1":1,"position1":' .. BlindPos .. ',"posKind2":2,"position2":0}}}'        -- Send position   res, code = http.request({   url = 'http://' .. Bridge .. '/api/shades/' .. ShadeID,   method = 'PUT',   headers = {     ['Content-Length'] = #body,     ['Content-Type'] = 'application/json',   },   source = ltn12.source.string(body) })   end
Br,
Mads
Maybe try adding steps in slider settings. You can then use arrows to change by step.
You can also check whether the object value changed after sleeping.
local value = event.getvalue() os.sleep(2) if grp.getvalue(event.dst) == value then   -- do something here end
