Can not change parameter visparams when using grp.create
.lua   51.lua (Size: 2.74 KB / Downloads: 3)
 I have a homeLynk HW 1.2 , Firmware 1.5.1 in operation for 7 years and now I have implemented scripts to read data from  a Kostal inverte Plenticore plus.
Had succes to read all 125 data point by Modbus TCP. I have generated all KNX Objekts by scripts and it works while using the essetial KNX object parameter with
grp.create.
myobject = grp.create({
    datatype = dt.float32,
    address = Gruppenaddresse,
    name = "Test float32 und visparams",
    units = " W",
    tags =  "Plenticore",
    visparams=grp_visparams
But I am failing to change the visualisation parameter  with the table of visparams.
After creating the object I read its parameter with
log("Grp lesen",grp.find(Gruppenaddresse))
but do not see the table visparams in the log
Changing the visu parameter manually and  do a
Now I have suuccess I got the string of visparams as json.
I have attached the script 51.lua with the lua code that is showing the described behaviour.
Need some information if it possible to change visparams by script using my HW/SW combination.
You have very old firmware which does not support setting visparams in grp.create.
(12.07.2022, 15:29)admin Wrote: You have very old firmware which does not support setting visparams in grp.create.
Thanks for immediate information. Unfortunatly I expected it.
You can do this via a direct DB query:
addr = '32/1/1' grp_visparams = {   ["max"]="10000",   ["min"]="0",   ["step"]="",   ["control"]="spinner",   ["decimals"]="0", } json_visparams = json.encode(grp_visparams) id = knxlib.encodega(addr) db:query('UPDATE objects SET visparams=? WHERE id=?', json_visparams, id)
(13.07.2022, 06:13)admin Wrote: You can do this via a direct DB query:
Great!!!!!! I took your code proposal, inserted it in my code and it is working. Smile Cool
Thank you very much for your support.
