16.08.2022, 20:53
		Hi.
I need help with a simple staircase timer script. Staircase with after dimming with two step.
When the trigger gets true 1/1/1, Timer 1 and Timer 2 starts and Set Value High to 1/1/2 Output.
After ten minutes the Set Value Low is set to 1/1/2 Output. If the time runs out it should write Set Value Off.
But every time the trigger recive true the timer 1 and 2 is retrigged.
If timer 2 is active and the trigger recive true it should set 90%.
1/1/1 Trigger Staircase 1bit
1/1/2 Output 1byte
Set Value High 90%
Set Value Low 20%
Set Value Off 0%
Set Timer 1 = 10min
Set Timer 2 = 20min
Br
1/1/2 Output 1byte
Set Value High 90%
Set Value Low 20%
Set Value Off 0%
Set Timer 1 = 10min
Set Timer 2 = 20min
Br
