18.08.2022, 12:00
Hello everyone,
Hope you're doing well.
I'm trying to link a fan coil thermostat with the following part number TC907-3A4LMA with the Logic machine, and my configuration of the thermostat was :
P12--Modbus Connection=On
P13--Modbus Address setting=01
P14--Modbus baud rate=4800
P15--Modbus Parity Check=Odd
and my configuration of Logic Machine was :
RTU serial =enabled
baud rate=4800
Parity Check=Odd
The issue is that when mapping objects it seems that no connection as shown in the attached image.
and the error log gives read failed as shown.
what should I do now?
Thanks for your time.
RTU serial =enabled
baud rate=4800
Parity Check=Odd
