	Threads: 7
		Good morning:I can't send the emails from Logic Machine
 In Scriptin, common funtions I have configured this way:
 -- send an e-mail
 local settings = {
 from = 'logicmahine@gmail.com',
 -- smtp username
 user = 'logicmahine@gmail.com',
 -- smtp password
 password = 'logicmachine1234',
 -- smtp server
 server = 'smtp.gmail.com',
 -- smtp server port
 port = 465,
 secure = 'sslv23',
 if type(to) ~= 'table' then
 to = { to }
 for index, email in ipairs(to) do
 to[ index ] = '<' .. tostring(email) .. '>'
 Then I created an event through a virtual object called Test
 value = event.getvalue()
 if value == true then
 mail('myemail@gmail.com','Alarma Prueba','Alarma Prueba')
 mail('myemail@gmail.com','No Alarma Prueba','Alarma Prueba Desactiva')
 But when the value of the event is "1" I don't receive any email
 I have verified that the mail I created for LM is operational
 Can you help me someone please?
 Josema
	Threads: 7
 Did you set the default GW and DNS correctly in the network settings?
 Otherwise log the err in the mail function, this will give you some direction what goes wrong..
	Threads: 87
		Code: -- send an e-mailfunction mail(to, subject, message)
 local settings = {
 from = 'example@gmail.com',
 -- smtp username
 user = 'example@gmail.com',
 -- smtp password
 password = 'mypassword',
 -- smtp server
 -- smtp server port
 port = 465,
 -- enable tls, required for gmail smtp
 secure = 'tlsv1_2',
 to = { to }
 -- fixup from field
 local from = '<' .. tostring(settings.from) .. '>'
 -- message headers and body
 headers = {
 to = table.concat(to, ', '),
 subject = subject,
 ['From'] = from,
 ['Content-type'] = 'text/html; charset=utf-8',
 body = message
 settings.from = from
 settings.rcpt = to
 return smtp.send(settings)
This works great for me, with gmail. Could the error be the secure line i see that you use ssl
	Threads: 7
		16.11.2019, 21:23
(This post was last modified: 16.11.2019, 21:28 by josemabera.)
		When I send a "true" through the virtual object, the following message appears in Error log:
User script:5: attempt to call global 'Log' (a nil value)
stack traceback:
 User script:5: in main chunk
I don't know what it means
  (16.11.2019, 11:54)Erwin van der Zwart Wrote:  Hi,
 Thanks for your response Erwin , but what is the GW? (Excuse my ignorance) , in the LM in System Confyg, network I don't see where to configure the DNS ..
BR ,
Josema
	Threads: 7
 Under System -> Network -> Interfaces you can double click on the NIC eth0 and there you can set the DNS and default GW (Gateway). When this is not set your controller can’t communicate with the internet and makes it impossible to send mail to Gmail (:
	Threads: 7
		17.11.2019, 11:30
(This post was last modified: 17.11.2019, 11:41 by josemabera.)
		 (16.11.2019, 22:01)Erwin van der Zwart Wrote:  Hi,Hi Erwin
 If  is configured
 DNS1= 8.8.8.8
 DNS2 = 8.8.4.4
 and the GW also is configured
 Even so it doesn't work, I can't attach Image captures to show you
  (16.11.2019, 20:32)Tokatubs Wrote:  Hi TokatubsThis works great for me, with gmail. Could the error be the secure line i see that you use sslCode: -- send an e-mailfunction mail(to, subject, message)
 local settings = {
 -- smtp username
 -- smtp password
 -- smtp server
 -- smtp server port
 port = 465,
 secure = 'tlsv1_2',
 to = { to }
 -- fixup from field
 headers = {
 subject = subject,
 ['From'] = from,
 body = message
 settings.rcpt = to
 I don't understand exactly what you tell me about the ssl Secure Line, how can I modify it to test what you tell me?
Josema
	Threads: 87
		If your problem is sending email with gmail, i think that you are using an old script. Take a look at line 16 it says tlsv1_2 and not Ssl as is in your script on the top.
 I had some problem some time ago, and Admin dropped the script i linked, and then i got the Gmail working. Could be worth a try..
	Threads: 7
		 (17.11.2019, 22:10)Tokatubs Wrote:  If your problem is sending email with gmail, i think that you are using an old script. Thank you very much for your response: I have changed line 16 from ssl to tlsv1_2 but I still do not receive the LM e-mails, I have tested it in the 3 LMs that I have installed in different projects, but I do not receive the e-mails, I miss it is that in one of the projects I did receive them with the common function of sending an e-mail with ssl, but now I do not receive themTake a look at line 16 it says tlsv1_2 and not Ssl as is in your script on the top.
 any other suggestions?
	Threads: 45
		log the result of mail function: Code: res, err = mail(...)log(res, err)
	Threads: 7
		 (18.11.2019, 07:31)admin Wrote:  log the result of mail function:Good morning Admin, thank you very much for the answer, this is the answer to the log:
 * arg: 1
 * nil
 * arg: 2
 * string: 535-5.7.8 Username and Password not accepted. Learn more at
 535 5.7.8 https://support.google.com/mail/?p=BadCredentials j3sm21727187wrs.70 - gsmtp
 As I have a moment I will check the username and password again, but have I done it before????
 Josema
	Threads: 29
------------------------------Ctrl+F5
	Threads: 7
		19.11.2019, 05:43
(This post was last modified: 19.11.2019, 05:47 by josemabera.)
		 (18.11.2019, 09:16)Daniel. Wrote:  It is probably thisGood morning Danielhttps://devanswers.co/allow-less-secure-...l-account/
 Thank you very much for the information, I have only allowed access to unsafe apps in the Gmail account and I already receive the test emails, in two of the three LMs that I have installed the third party does not send them to me, I will check the account carefully something must not be right
Josema
  (17.11.2019, 22:10)Tokatubs Wrote:  If your problem is sending email with gmail, i think that you are using an old script. Hi TokabusTake a look at line 16 it says tlsv1_2 and not Ssl as is in your script on the top.
 after several tests
 the script works with ssl, the problem was with the gmail account that I solved by enabling access to unsafe Apps on the account
 Thank you very much for your help
 Josema
	Threads: 2
I trying to use the same script as above, but when I enter my new google account made for testing with LM, and enter "less secure app access" https://devanswers.co/allow-less-secure-...l-account/  it says that "this setting is not supported by google anymore".
Does that mean that I cant use a @gmail to send e-mails from LM anymore?
	Threads: 29
	Threads: 2
0 |
