Replace Micro SD Card issue
Hello
I have an issue with the SL Micro SD Card, its become read only.
I make the first step using the USB Image tool
then I open the browser clear the cash >> choose the Image file>> Upload then I have this Message:
Bad Gateway
the process didn't produce any response
Best Regards,
Try this recovery image: https://dl.openrb.com/recovery-mxs-1g.img.gz
(12.09.2022, 08:54)admin Wrote: Try this recovery image: https://dl.openrb.com/recovery-mxs-1g.img.gz
How much time it should take, more than 10min elapsed but still not finished!
Best Regards,
It should take no more than 5 minutes to finish. Can you ping the device?
Hello Admin
This recovery image should I use it to create the MicroSD Card with the USB Image tool?
Best Regards,
Yes, the same way as with the older recovery. But you should see the same window as for standard firmware upgrade.
(12.09.2022, 10:24)admin Wrote: Yes, the same way as with the older recovery. But you should see the same window as for standard firmware upgrade.
Thanks Admin
Its worked now
But what could make the original recovery file not working?
Best Regards,
It's an older recovery image with 16MB upload file limit. Newer firmwares are larger so you get an error. Updated recovery image can handle firmwares up to 32MB.
