lots of curve with highlight
Hi, Is there a way to scroll the the list to the good curve the mouse pointer is above.
I explain. When using lots of curve like here:
Sometimes we need to go over a point but the name curve is at the bottom of the list, so hard to find the right value.
Is there a css trick or JS ?
Regards
SE ECO EXPERT
This will be fixed in the next release. In the meantime you can use this custom JS:
$(function(){   if (window.Chart) {     Chart.$c.on('mousemove', function() {       var el = document.querySelector('.flotr-legend-hl');       if (el) {         el.scrollIntoView();       }     });   } });
thks a lot !
SE ECO EXPERT
