19.09.2022, 09:42
Hi everybody!
Is there a command to run a script? I have found only enable/disable commands(
Script run
19.09.2022, 09:42
Hi everybody!
19.09.2022, 09:46
What exactly do you want to do? If you have some common code that you need to run from different scripts you can wrap it into a function and place it into Common functions or a User library.
19.09.2022, 11:29
Lets say I have time based script, which starts every 30 minutes. I need to call it from event based script.
19.09.2022, 13:01
Then do as I suggested: wrap your code into a function and place it into Common functions or a User library. Then call this function from both scheduled and event scripts.
21.09.2022, 13:32
Thank you, will do that.
