08.11.2022, 18:59
I need to share the status of group addresses (address, name, data, datatype, time) so that both W4Ks have current values from the other side from the KNX bus.
Is it possible to use for example "reading object values using XML" described here https://openrb.com/example-read-knx-obje...using-xml/ ?
The idea is this:
a) load objects from W4k-1 to W4K-2 marked "export" once every 2 minutes and overwrite existing objects in W4K-2 according to addresses
b) load objects from W4k-2 to W4K-1 marked "export" once every 2 minutes and overwrite existing objects in W4k-1 according to addresses
Alternatively, another suggestion?
Thank you
The idea is this:
Thank you
