Power price API -> grp. adresses on Wiser
Hello people! Big Grin
Im all new to all this scripting thing with my Wiser.
I have been looking at the forum, and found an other script that more or less say it does what I want.
Then i've changed some of the parameters and the API.
When I run the script i just get this awnswer in the alert log:
Resident script:12: attempt to index a nil value
stack traceback:
Can anyone help? Tongue
require('json') https = require 'ssl.https' date = os.date('%Y-%m-%d') url = 'https://api.energidataservice.dk/dataset/Elspotprices?offset=0&filter=%7B%22PriceArea%22:%22dk1%22%7D&sort=HourDK%20DESC&timezone=dk&limit=24' status = ssl.https.request(url) data = json.decode(status) price1 = data[1].SpotPriceDKK grp.checkupdate('5/5/1', price1) price2 = data[2].SpotPriceDKK grp.checkupdate('5/5/2', price2) price3 = data[3].SpotPriceDKK grp.checkupdate('5/5/3', price3) price4 = data[4].SpotPriceDKK grp.checkupdate('5/5/4', price4) price5 = data[5].SpotPriceDKK grp.checkupdate('5/5/5', price5) price6 = data[6].SpotPriceDKK grp.checkupdate('5/5/6', price6) price7 = data[7].SpotPriceDKK grp.checkupdate('5/5/7', price7) price8 = data[8].SpotPriceDKK grp.checkupdate('5/5/8', price8) price9 = data[9].SpotPriceDKK grp.checkupdate('5/5/9', price9) price10 = data[10].SpotPriceDKK grp.checkupdate('5/5/10', price10) price11 = data[11].SpotPriceDKK grp.checkupdate('5/5/11', price11) price12 = data[12].SpotPriceDKK grp.checkupdate('5/5/12', price12) price13 = data[13].SpotPriceDKK grp.checkupdate('5/5/13', price13) price14 = data[14].SpotPriceDKK grp.checkupdate('5/5/14', price14) price15 = data[15].SpotPriceDKK grp.checkupdate('5/5/15', price15) price16 = data[16].SpotPriceDKK grp.checkupdate('5/5/16', price16) price17 = data[17].SpotPriceDKK grp.checkupdate('5/5/17', price17) price18 = data[18].SpotPriceDKK grp.checkupdate('5/5/18', price18) price19 = data[19].SpotPriceDKK grp.checkupdate('5/5/19', price19) price20 = data[20].SpotPriceDKK grp.checkupdate('5/5/20', price20) price21 = data[21].SpotPriceDKK grp.checkupdate('5/5/21', price21) price22 = data[22].SpotPriceDKK grp.checkupdate('5/5/22', price22) price23 = data[23].SpotPriceDKK grp.checkupdate('5/5/23', price23) price24 = data[24].SpotPriceDKK grp.checkupdate('5/5/24', price24) medelpris = price1+price2+price3+price4+price5+price6+price7+price8+price9+price10+price11+price12+price13+price14+price15+price16+price17+price18+price19+price20+price21+price22+price23+price24 gennemsnit = medelpris / 24 grp.checkupdate('5/5/25', gennemsnit) maxpris = math.max(price1, price2, price3, price4, price5, price6, price7, price8, price9, price10, price11, price12, price13, price14, price15, price16, price17, price18, price19, price20, price21, price22, price23, price24) grp.checkupdate('5/5/26', maxpris) minpris = math.min(price1, price2, price3, price4, price5, price6, price7, price8, price9, price10, price11, price12, price13, price14, price15, price16, price17, price18, price19, price20, price21, price22, price23, price24) grp.checkupdate('5/5/27', minpris) log(price1, price2)
Try this:
url = 'https://api.energidataservice.dk/dataset/Elspotprices?offset=0&filter=%7B%22PriceArea%22:%22dk1%22%7D&sort=HourDK%20DESC&timezone=dk&limit=24' resp = require('ssl.https').request(url) data = require('json').decode(resp).records max = 0 min = math.huge sum = 0 for i, item in ipairs(data) do   price = item.SpotPriceDKK   max = math.max(max, price)   min = math.min(min, price)   sum = sum + price   grp.checkupdate('5/5/' .. i, price) end avg = sum / #data grp.checkupdate('5/5/25', avg) grp.checkupdate('5/5/26', max) grp.checkupdate('5/5/27', min)
Thats perfect! Big Grin
Work like a charm! But again, im totally noob, so what do I do to get all 24 hours of the day?
I've done this: (changed the "5/5/ .. i," to 5/5/1.
It gives me 836,75000 in a 4 byte float object.
url = 'https://api.energidataservice.dk/dataset/Elspotprices?offset=0&filter=%7B%22PriceArea%22:%22dk1%22%7D&sort=HourDK%20DESC&timezone=dk&limit=24' resp = require('ssl.https').request(url) data = require('json').decode(resp).records max = 0 min = math.huge sum = 0 for i, item in ipairs(data) do   price = item.SpotPriceDKK   max = math.max(max, price)   min = math.min(min, price)   sum = sum + price   grp.checkupdate('5/5/1', price) end avg = sum / #data grp.checkupdate('5/5/25', avg) grp.checkupdate('5/5/26', max) grp.checkupdate('5/5/27', min)
Use the script as is without any modifications. It outputs the hourly data to 5/5/1 .. 5/5/24.
(10.11.2022, 08:49)admin Wrote: Use the script as is without any modifications. It outputs the hourly data to 5/5/1 .. 5/5/24.
Ah okay Smile  Works nicely. The avg, max, min, however doesnt seem to be working?
Would it be possible to isolatae the cheapest 4 hours?
Would you mind spending 5 min explaining what the different lines do?
What exactly is not working for min/max/avg? Do you have objects created with correct data type?
This will produce a string with cheapest 4 hours. Set 5/5/28 datatype to 250 byte string.
url = 'https://api.energidataservice.dk/dataset/Elspotprices?offset=0&filter=%7B%22PriceArea%22:%22dk1%22%7D&sort=HourDK%20DESC&timezone=dk&limit=24' resp = require('ssl.https').request(url) data = require('json').decode(resp).records max = 0 min = math.huge sum = 0 for i, item in ipairs(data) do   price = item.SpotPriceDKK   max = math.max(max, price)   min = math.min(min, price)   sum = sum + price   grp.checkupdate('5/5/' .. i, price)   item.hour = tonumber(item.HourDK:match('T(%d+)')) end avg = sum / #data grp.checkupdate('5/5/25', avg) grp.checkupdate('5/5/26', max) grp.checkupdate('5/5/27', min) table.sort(data, function(a, b)   return a.SpotPriceDKK < b.SpotPriceDKK end) list = {} for i = 1, 4 do   item = data[ i ]   list[ #list + 1 ] = string.format('%d = %.2f', item.hour, item.SpotPriceDKK) end hours = table.concat(list, '; ') grp.checkupdate('5/5/28', hours)
For general info on Lua read this book: http://www.lua.org/pil/contents.html
Thanks alot! Big Grin
I've ended up with this, and it seems to be working. I have tried to make the script move the values over to the storage, once a day, to visualise the right cost at the right time Smile
Dont mind the danish text at the right side, im just trying to make my way through the code Tongue
url = 'https://api.energidataservice.dk/dataset/Elspotprices?offset=0&filter=%7B%22PriceArea%22:%22dk1%22%7D&sort=HourDK%20DESC&timezone=dk&limit=24' resp = require('ssl.https').request(url) data = require('json').decode(resp).records max = 0        --nulstiller max værdi min = math.huge        --nulstiller min værdi med uendeligt stort tal sum = 0        --nulstiller sum værdi        --Skriver time:minutter i "tid".        -- %a    abbreviated weekday name (e.g., Wed)        -- %A    full weekday name (e.g., Wednesday)        -- %b    abbreviated month name (e.g., Sep)        -- %B    full month name (e.g., September)        -- %c    date and time (e.g., 09/16/98 23:48:10)        -- %d    day of the month (16) [01-31]        -- %H    hour, using a 24-hour clock (23) [00-23]        -- %I    hour, using a 12-hour clock (11) [01-12]        -- %M    minute (48) [00-59]        -- %m    month (09) [01-12]        -- %p    either "am" or "pm" (pm)        -- %S    second (10) [00-61]        -- %w    weekday (3) [0-6 = Sunday-Saturday]        -- %x    date (e.g., 09/16/98)        -- %X    time (e.g., 23:48:10)        -- %Y    full year (1998)        -- %y    two-digit year (98) [00-99]        -- %%    the character `%´ tidtimer = os.date("%H") tidminutter = os.date("%M") for i, item in ipairs(data) do   price = item.SpotPriceDKK/1000        --tildeler ordet price værdien af feltet SpotPriceDKK og deler med 1000 for at gå fra GW til KW.   max = math.max(max, price)   min = math.min(min, price)   sum = sum + price   grp.checkupdate('13/4/' ..i, price)   item.hour = tonumber(item.HourDK:match('T(%d+)'))        --Gemmer prisen fra igår i datalager under Spotpris1...23   if tidtimer == 12 and tidminutter == 00 then   storage.set('Spotpris' ..i, price)     end end avg = sum / #data grp.checkupdate('13/4/25', avg) grp.checkupdate('13/4/26', max) grp.checkupdate('13/4/27', min) table.sort(data, function(a, b)   return a.SpotPriceDKK < b.SpotPriceDKK end) list = {} for i = 1, 4 do   item = data[ i ]   list[ #list + 1 ] = string.format('%d = %.2f', item.hour, item.SpotPriceDKK) end hours = table.concat(list, '; ') grp.checkupdate('13/4/28', hours)        -- viser angivede enheder i loggen log(avg, max, min, tidtimer, tidminutter, hours)
