21.12.2016, 14:57
Somehow (probably the screen has been made in a previous firmware build) it happened I've an object which is invisible in usermode but visible in touch mode. The problem is the object has no axes and size.
I exported the window and ther's this row:
{"object":63489,"id":3092,"params":"{\"size\":\"\",\"bold\":0,\"italic\":0,\"underline\":0,\"width\":56,\"height\":56,\"icon_on\":\"staircase-down-7A7F71-010101.svg\",\"icon_off\":\"staircase-down-A0F007-010101.svg\",\"icon_touch\":\"\",\"icons_add\":[],\"displaymode\":\"icon\",\"showcontrol\":0,\"fixedvalue\":\"\",\"update\":false,\"pincode\":\"\",\"widget\":81,\"backdrop\":0}"
You can see size parameters are empty.
Is there any workaround how to delete this object from my visualisation?
I don't want export it into a tar file, delete it from the file and import the file back because this visu has been linked to another visu pages.
