apple tv standby
Is there a way to standby an Apple tv from a LM script?
There are some solutions in Python and NodeJS but that's not something that can be run on LM as is.
Home Assistant support Apple TV standby, so i used that product also.
So make a script in Home Assistant and run that script with the LM
https = require('ssl.https') json = require('json') ltn12 = require('ltn12') token = "xxxxxxxxxxxxxx" --generate long use token in HA (10 years lifetime) function runScript(iDevice, iScript, iScriptId)   data = json.encode({     query = '{"entity_id": "'..iScriptId..'"}'   })   tbl = {}   res, code = https.request({     url = 'http://'..iDevice..'/api/services/script/'..iScript,     method = 'POST',     headers = {       ['authorization'] = 'Bearer ' .. token,       ['content-type']  = 'application/json',       ['content-length'] = #data,     },     source = ltn12.source.string(data),     sink = ltn12.sink.table(tbl),   })   --[[   if res and code == 200 then     resp = table.concat(tbl)     resp = json.pdecode(resp)     log(resp)   else     log(res, code)   end   --]] end -- standby apple tv woonkamer (ip, scriptname, scriptid) --runScript("192.168.X.XX:8123", "AppleTVWoonkamer_Standby", "script.appletvwoonkamer_standby")
