Hi, I want to control an Onkyo device through TCP using eISCP. The protol information can be seen here at section 1.2
https://tascam.com/downloads/tascam/790/...otocol.pdf
I found out some other code to control it using php
https://www.domoticz.com/wiki/Onkyo
or ruby
https://gist.github.com/also/3546825
I use this python code and it work perfectly from my computer
https://github.com/miracle2k/onkyo-eiscp
I try to make some code like below to power on the Onkyo from LM but it didnt work
Can you help me to make this code work? Thank you very much
or ruby
cmd = 'ISCP\x00\x00\x00\x10\x00\x00\x00\x08\x01\x00\x00\x00!1PWR01\x0D'
require('socket')
sock=socket.tcp()
sock:settimeout(2)
a=sock:connect('192.168.1.100',60128)
b=sock:send(cmd)Can you help me to make this code work? Thank you very much
