14.12.2022, 12:20
Is there support for DALI 2?
[OLD] LogicMachine firmware 2021.12
14.12.2022, 12:20
14.12.2022, 12:24
CANx-DALI has support for parsing DALI2 telegrams: https://openrb.com/docs/canxdali-dali2.htm
There are currently no plans to add DALI2 support to non-CANx interfaces (internal and RS485).
14.12.2022, 12:56
Can I assign addresses and control the brightness of a lamps that has DALI2 with DW1?
14.12.2022, 12:57
What is the lamp make/model?
14.12.2022, 13:01
Centrsvet INF LINE 800 1630 WD DALI 2
Centrsvet INF TURN LINE 200 0530 WD DALI 2
14.12.2022, 13:09
Most DALI2 ballasts are backward-compatible with DALI1. Ask the ballast manufacturer for confirmation that it will work.
11.01.2023, 22:05
(14.12.2022, 12:20)Boolkinator Wrote: Is there support for DALI 2? I have the same issue trying to use Dali for the first time on the Dali built-in master. My luminaire only has Dali 2: https://www.datocms-assets.com/47741/164...d2z0c1.pdf Any chance to get Dali 2 also implemented on non-CANx? Thanks, Kristof
12.01.2023, 14:47
Currently CANx-DALI does not have full DALI2 support. No decision has been made whether to support DALI2 on older devices.
16.01.2023, 23:23
Hi all,
It was due to a bad power supply that I did not manage to get Dali working. Dali 2 is fully supported on older LogicMachine devices by sending raw commands on the bus. I was able to set the color temperature of a Dali Device Type (DT) 8. Thank you for the wonderful products you build, it was a delight to work with the Dali internal gateway as defined in https://openrb.com/docs/dali.htm
04.02.2023, 12:05
Which firmware is the correct one for this device?
log(io.readfile('/proc/device-tree/model')): i.MX28 LM2 Re:actor My current firmware version is 20170620 (old). Can I upgrade directly to 2021.12 or should I first upgrade to mid versions? Btw, thanks for continued support of older devices ![]()
06.02.2023, 06:13
Use this firmware (LM Reactor V1): https://dl.openrb.com/lm-21-mxs/reactor-20211215.img
