4 bit dimming script
script for 4 bit dimming to send command to 1 Byte unsigned integer dimming
Have a look here
https://forum.logicmachine.net/showthrea...27#pid8027
In 2022 RC1 firmware and later you can use an event script with execution mode set to "Last instance only". Change parameters on first three lines as needed.
out = '1/1/2' -- output group address (1 byte scale) stepsize = 5 -- step size in % sleeptime = 0.5 -- delay in seconds between each step dimmer = event.getvalue() step = bit.band(dimmer, 0x07) if step == 0 then   return end if bit.band(dimmer, 0x08) == 0 then   stepsize = -stepsize end value = grp.getvalue(out) while true do   newvalue = math.min(value + stepsize, 100)   newvalue = math.max(newvalue, 0)   if newvalue == value then     break   end      value = newvalue   grp.write(out, value)   os.sleep(sleeptime) end
