How to control the KNX bus via SMS and send notices via SMS?
#41
If you want to use API why not use Telegram instead? It's free and easy to configure. See this: https://forum.logicmachine.net/showthrea...1#pid17111
with the instruction and files in post 3 I am now able to receive and send sms. THX!
I also managed to reboot via SMS and get back some information (e.g. IP) when sending a sms with "status" as content to LM.
I now want to get back the signal status of the modem via sms.
ASFAIK the AT-Command "AT+CSQ" delivers this information but unfortunately I have no clue how to implement this (my lua and AT-Command skills are not the best Smile ).
Can anyone help?
Thx in advance!
1. Modify the user library send function so it returns the command reply/result:
-- send command to terminal
function AT:send(cmd)
  local res, err = self.port:write(cmd .. '\r\n')
  local reply
  -- write ok, get local echo
  if res then
    res, err = self:readuntil(cmd)
    reply = self:read()
  return res, err, reply
2. Add before handler = function(sms) in the resident script:
readcsq = function()
    local res, err, reply = modem:send('AT+CSQ')
    local rssi
    if reply then
      rssi = reply:match('%+CSQ:%s+(%d+),(%d+)')
    rssi = tonumber(rssi) or 0
    if 2 <= rssi and rssi <= 9 then
      quality = 'marginal'
    elseif 10 <= rssi and rssi <= 14 then
      quality = 'ok'
    elseif 15 <= rssi and rssi <= 19 then
      quality = 'good'
    elseif 20 <= rssi and rssi <= 30 then
      quality = 'excellent'
      quality = 'unknown'
  csqtime = os.time()
3. Add before udphandler(server) in the resident script:
now = os.time()
    delta = math.abs(now - csqtime)
    if delta >= 15 then
      csqtime = now
      readcsq()
This will read the signal quality every 15 seconds and will set global variable quality that you can use in the SMS reply message.
Works perfect - THX!
Is it possible to change APN via SMS and reconnect to the new APN? I am sure it is but my skills ...
I need this to connect to my LM in case the VPN is down.
Normally I use the APN "internet.telekom, tm ,tm" and do not want to change this default setting (bacause of security reasons) - with this APN you get a private WAN-IP like 10.x.x.x and AFAIK you can not connect to private IPs.
With the APN "internet.t-d1.de, internet, t-d1" you get a non private IP like 32.x.x.x and you can connect to it.
Another point: In the resident script the PIN code needs to be set - either as a number or a object-variable. Is it also possible to get the PIN code out of the system preferences where it usually also has to be set?
THX in advance!
