Change Duplex settings through scripts
is it possible to change this setting through scripting?
Can you explain why do you need to change it? For RS485 duplex must be set to half. It won't work with full duplex.
(09.01.2023, 07:48)admin Wrote: Can you explain why do you need to change it? For RS485 duplex must be set to half. It won't work with full duplex.
I have a  smart RS485 energy meter 'Inepro MOD380' After every time the grid turns off LM5 doesnt see the signal, then if i change to full-duplex and then back to half-duplex it suddenly works again, it is the only way it reconnects to the meter.
That is why
You can restart Modbus via a script like this:
os.execute('sh /lib/genohm-scada/plugins/modbus/stop.sh') os.sleep(1) os.execute('sh /lib/genohm-scada/plugins/modbus/start.sh')
(09.01.2023, 18:22)Robikozo Wrote:
(09.01.2023, 07:48)Hello, Wrote: Do you have the Modbus profile?
Greetings, Sebastian
