RGB to separate objects
Hi. I know I've seen it on the forum before, but could not find it.
To get RGB to work in Google Home, I need to convert RGB (232.600) to separate 1byte values. And also convert the status back from 1byte to 232.600.
Hi, I asked your question to the chatgpt AI and got a working result, hope this works for you too.
Function to convert KNX RGB datatype to separate 1-byte values:
function knxRGBToBytes(knxRGB)     local red = bit.rshift(bit.band(knxRGB, 0xFF0000), 16)     local green = bit.rshift(bit.band(knxRGB, 0x00FF00), 8)     local blue = bit.band(knxRGB, 0x0000FF)     return red, green, blue end -- Example usage local knxRGB = grp.getvalue('x/x/x') local red, green, blue = knxRGBToBytes(knxRGB) log(red, green, blue)
The other function convert separate 1-byte values to KNX RGB datatype:
function bytesToKNXRGB(red, green, blue)     local knxRGB = bit.lshift(red, 16) + bit.lshift(green, 8) + blue     return knxRGB end -- Example usage local red, green, blue = 255, 102, 51 local knxRGB = bytesToKNXRGB(red, green, blue) log(string.format("%X", knxRGB))
