Error while writing to ftp
I am trying to write files to external ftp. I get the following answer from the ftp-server:
504 Form must be N or T
What does this mean? I have tested the script to a server I set up for testing, and it worked, but in the real server where the files are t o be written I am not able to write.
ftpAdresse = '192.168.0.198' ftpMappeDaily = '/FTPtest/Daily/' ftpMappeHistory = '/FTPtest/History/' username = 'Spacelynk' pw = 'Test123' ----------------------------------------------------------------------------------------------------------------------- --Finner alle lamper i anlegget ----------------------------------------------------------------------------------------------------------------------- lamper = db:getall('SELECT name FROM objects WHERE name LIKE "%TEST_RESULT%"') ----------------------------------------------------------------------------------------------------------------------- --Navnelister resultater fra test ----------------------------------------------------------------------------------------------------------------------- LTRF = {   {val = 0, Text = 'Unknown'},   {val = 1, Text = 'Passed in time'},   {val = 2, Text = 'Passed max delay exceeded'},   {val = 3, Text = 'Failed, test executed in time'},   {val = 4, Text = 'Failed, max delay exceeded'},   {val = 5, Text = 'Test manually stopped'},   {val = 6, Text = 'Invalid value; 6'},     {val = 7, Text = 'Invalid value; 7'},   {val = 8, Text = 'Invalid value; 8'},   {val = 9, Text = 'Invalid value; 9'},   {val = 10, Text = 'Invalid value; 10'},   {val = 11, Text = 'Invalid value; 11'},   {val = 12, Text = 'Invalid value; 12'},   {val = 13, Text = 'Invalid value; 13'},   {val = 14, Text = 'Invalid value; 14'},   {val = 15, Text = 'Invalid value; 15'}, } LTRD = {   {val = 0, Text = 'Unknown'},   {val = 1, Text = 'Passed in time'},   {val = 2, Text = 'Passed max delay exceeded'},   {val = 3, Text = 'Failed, test executed in time'},   {val = 4, Text = 'Failed, max delay exceeded'},   {val = 5, Text = 'Test manually stopped'},   {val = 6, Text = 'Invalid value; 6'},   {val = 7, Text = 'Invalid value; 7'},   {val = 8, Text = 'Invalid value; 8'},   {val = 9, Text = 'Invalid value; 9'},   {val = 10, Text = 'Invalid value; 10'},   {val = 11, Text = 'Invalid value; 11'},   {val = 12, Text = 'Invalid value; 12'},   {val = 13, Text = 'Invalid value; 13'},   {val = 14, Text = 'Invalid value; 14'},   {val = 15, Text = 'Invalid value; 15'}, } SF = {   {val = 0, Text = 'Unknown'},   {val = 1, Text = 'Started automatically'},   {val = 2, Text = 'Started by Gateway'},   {val = 3, Text = 'Reserved'}, } SD = {   {val = 0, Text = 'Unknown'},   {val = 1, Text = 'Started automatically'},   {val = 2, Text = 'Started by Gateway'},   {val = 3, Text = 'Reserved'}, } ----------------------------------------------------------------------------------------------------------------------- --Oppretter filer for lagring av verdier ----------------------------------------------------------------------------------------------------------------------- now = os.date('*t') time = { day = wday, hour = now.hour, minute = now.min, second = now.sec, } reportFile = string.format('CurrentReport.csv') historyFile = string.format('%s-Report.csv', os.date('%d-%m-%Y',log_start)) reportBuffer = {'Resultater fra test.',  'Test startet; ' .. os.date('%d/%m-%Y',log_start) .. ' klokken ' .. time.hour .. '.' .. time.minute ,   'Rom; Lampe; Siste funksjonstest; Siste batteritest; Startmetode FT; Startmetode BT' } ----------------------------------------------------------------------------------------------------------------------- -- Henter verdier fra lamper ----------------------------------------------------------------------------------------------------------------------- for _, lampe in ipairs(lamper) do   navn = lampe.name   rom = string.split(navn, ' =')[1]   lampe = '=' .. string.split(string.split(navn, '=')[2], ' ')[1]   --log(rom, lampe)   verdi = grp.getvalue(navn)   --Finner LTRF   for _, linje in ipairs(LTRF) do     if linje.val == verdi.ltrf then       LTRF_text = linje.Text     elseif verdi.ltrf == nil then       LTRF_text = 'Not found'     end   end   --Finner LTRD   for _, linje in ipairs(LTRD) do     if linje.val == verdi.ltrd then       LTRD_text = linje.Text     elseif verdi.ltrd == nil then       LTRD_text = 'Not found'     end   end    --Finner SF   for _, linje in ipairs(SF) do     if linje.val == verdi.sf then       SF_text = linje.Text     elseif verdi.sf == nil then       SF_text = 'Not found'     end   end   --Finner SD   for _, linje in ipairs(SD) do     if linje.val == verdi.sd then       SD_text = linje.Text     elseif verdi.sd == nil then       SD_text = 'Not found'     end   end   table.insert(reportBuffer, rom .. ';' .. lampe .. ';' .. LTRF_text .. ';' .. LTRD_text .. ';' .. SF_text .. ';' .. SD_text)     --log(navn, LTRF_text, LTRD_text, SF_text, SD_text)   --log(navn, verdi) end ----------------------------------------------------------------------------------------------------------------------- -- Skriver fil til SL HD ----------------------------------------------------------------------------------------------------------------------- rapport = string.char(0xEF, 0xBB, 0xBF) csv = rapport .. table.concat(reportBuffer, '\r\n') result, err = io.writefile ('/home/ftp/' .. reportFile, csv) resultHist, err = io.writefile ('/home/ftp/' .. historyFile, csv) log(result, err) ----------------------------------------------------------------------------------------------------------------------- -- Skriver fil til FTP; historisk fil og dagens fil ----------------------------------------------------------------------------------------------------------------------- local ftp = require("socket.ftp") local ltn12 = require("ltn12") targetHist = ftpMappeHistory .. historyFile targetDay = ftpMappeDaily .. reportFile log(targetHist) dst = '/home/ftp/' .. historyFile f, e = socket.ftp.put{   host = ftpAdresse,   user = username,   password = pw,   type = "a n",   argument = targetHist,   source = ltn12.source.file(io.open(dst, "rb"))   } if (e) then   log (e)   log (f)   alert("Could not ftp: ", e, "\n") end log(targetDay) dst = '/home/ftp/' .. reportFile f, e = socket.ftp.put{   host = ftpAdresse,   user = username,   password = pw,   type = "a n",   argument = targetDay,   source = ltn12.source.file(io.open(dst, "rb"))   } if (e) then   log (e)   log (f)   alert("Could not ftp: ", e, "\n") end
"type" argument for ftp.put must be a single letter. You can also remove it completely, it should work without it in most cases.
(06.02.2023, 14:17)admin Wrote: "type" argument for ftp.put must be a single letter. You can also remove it completely, it should work without it in most cases.
Great. That did it!
