API esios ree
#21
Use grp.create: https://openrb.com/docs/lua.htm#grp.create
thanks for the reply.
Would it be possible to do it automatically, specifying a minimal virtual object up to a maximum?
regards
hello, esios change the header for autentification in their API, from
curl "https://api.esios.ree.es/indicators" -X GET
-H "Accept: application/json; application/vnd.esios-api-v1+json"
-H "Content-Type: application/json" -H "Host: api.esios.ree.es"
-H "Authorization: Token token=\" 96c56fcd69dd5c29f569ab3ea9298b37151a1ee488a1830d353babad3ec90fd7\""
-H "Cookie: "
to (https://apip.esios.ree.es/doc/index.html)
curl "https://api.esios.ree.es/archives" -X GET \
-H "Accept: application/json; application/vnd.esios-api-v1+json" \
-H "Content-Type: application/json" \
-H "x-api-key:\"96c56fcd69dd5c29f569ab3ea9298b37151a1ee488a1830d353babad3ec90fd7\"" \
In the script of this post I try to change:
Quote:--Token=('Token token=\34'..token..'\34')
Token=('\34'..token..'\34')
body, code, hdrs, stat = https.request ({ --Llamada HTTP formada por URL+metodo+cabecera
  url = url;
  method = 'GET';
  headers = {
        ['Accept'] = 'application/json; application/vnd.esios-api-v1+json';
        ['Content-Type'] = 'application/json';
        ['Host'] = 'api.esios.ree.es';
--        ['Authorization'] = Token;
        ['x-api-key'] = Token;
        ['Cookie'] = '';
    source = ltn12.source.string(payload);
    sink = ltn12.sink.table(response_body);
but, the return code is 401, error with authentification
Anyone was able to update the request to new way?
thanks for your help
Does it work if you send the same request using curl?
yes, old curl (valid until end of this month) and new curl return the json. But I am not able make it works properly
curl "https://api.esios.ree.es/indicators/1001?start_date=15-02-2023T00%3A00&end_date=15-02-2023T23%3A50&geo_ids[]=8741" -X GET \
-H "Host: api.esios.ree.es" \
-H "Authorization: Token token=\"xxxxxxxxxxxxxxxxxxxxx\"" \
-H "Cookie: "
-H "x-api-key:\"xxxxxxxxxxxxxxxxxxxxx\"" \
-H "Cookie: "
(16.02.2023, 14:33)jose_dli Wrote: yes, old curl (valid until end of this month) and new curl return the json. But I am not able to make it works properly
-H "Cookie: "
-H "Cookie: "
Can you send your access token via PM?
Thanks. It seems that their API does not accept the key when there's a space in the key header: x-api-key: "...". HTTP library always sends headers this way. Can you contact them and ask if they can fix it on their side?
thanks a lot, I'll write them, if any news, I'll come back
the problem was the quotes in the token and that esios had two servers to make test.
The way is as follow:
token='xxxxxxxxxxxxxx'
  url = url;
  method = 'GET';
  headers = {
        ['x-api-key'] = token;
