Gate opener optimization
Hey
I have made this script to open and close my gate, it works almost all the time Smile
I'm not a programmer at all, so maybe someone can tell me if there is a better/easier/more correct way to make it work 100% all the time.
I have a 4x knx relay where I only use 3 relays
First one (2/2/0) is to control a contactor that  supplies power to a big 3x400vAC to 24vDC transformer.
Second one (2/2/2) is to tell my actuators to close.
Third one (2/2/4) is to tell my actuators to open.
32/1/1 is just to open a widget with the controls.
32/1/4 is to show the status of the gate, open or closed
There is mechanical stops on the gate if it hits something.
close = event.getvalue() status = grp.getvalue('32/1/4') if close== true and   status== false then   grp.write('2/2/0', 'true')   os.sleep(1.5)   grp.write('2/2/2', 'true')   os.sleep(12)   grp.write('2/2/2', false)   os.sleep(1.5)   grp.write('2/2/0', false)   grp.update('32/1/2', false)   grp.update('32/1/4', true)     elseif     grp.getvalue('32/1/2')     then     grp.update('32/1/2', false)     end
open = event.getvalue() status = grp.getvalue('32/1/4') if open== true and   status== true then   grp.write('2/2/0', 'true')   os.sleep(1.5)   grp.write('2/2/4', 'true')   os.sleep(12)   grp.write('2/2/4', false)   os.sleep(1.5)   grp.write('2/2/0', false)   grp.update('32/1/3', false)   grp.update('32/1/4', false)     elseif     grp.getvalue('32/1/3')     then     grp.update('32/1/3', false)     end
[Image: rwd9zEx.png]
What happens when the script is not working correctly? Maybe the start-up time for the power supply needs to be longer? The delay after the movement can be shorter.
The code looks correct, apart from 'true' in quotes. It works because non-empty string evaluates as boolean true. But if you write 'false' you will get true instead.
