Scene on Mosaic
Good afternoon,
A simple info.... Is it possible create event script to run scene created in mosaic?
Best regards Cristian
Try this. Change title variable to the title of your scene widget (case sensitive). If you have multiple scenes with the same title then this script will run all such scenes.
title = 'my scene'
config = storage.exec('get', 'mosaic30:config:0')
config = require('json').decode(config)
function checkwidget(widget)
  if widget.type ~= 'user_scene' then
    return
  elseif widget.title ~= title then
    return
  for addr, value in pairs(widget.settings.objects) do
    grp.write(addr, value)
for _, floor in ipairs(config.floors or {}) do
  for _, room in ipairs(floor.rooms or {}) do
    for _, widget in ipairs(room.widgets or {}) do
      checkwidget(widget)
(30.03.2023, 05:55)admin Wrote: Try this. Change title variable to the title of your scene widget (case sensitive). If you have multiple scenes with the same title then this script will run all such scenes.
title = 'my scene'
    return
    return
      checkwidget(widget)
Thanks admin, I will try and I let you know.
title = 'my scene'
    return
    return
      checkwidget(widget)
Hi admin,
tested and it works, thank you so much.
Could I suggest an improve?
It could be interesting add some delay between a command and other. It could be useful for scene that interest TV command for example.
BR Cristian
