Script for Reboot
Hello Daniel.
Is it possible to create a script for reboot the LM?
Try this:
os.execute('reboot')
Be careful with this, if you loop controller in constant reboot, the only way out is hardware factory reset.
(05.04.2023, 19:09)palomino Wrote: Hello Daniel.
just make backup defore implementing ths code))
Is it also possible to get a notification when it restarts?
(08.04.2023, 13:58)Dré Wrote: Is it also possible to get a notification when it restarts?
-- Common Function
function mail(to, subject, message)
  local settings = {
    from = 'servis@servis.com',
    -- smtp username
    user = 'username',
    -- smtp password
    password = 'password',
    -- smtp server
    server = 'smtp.myserver.com',
    -- smtp server port
    port = 25,
--    secure = 'sslv23',
-- port 465
  if type(to) ~= 'table' then
    to = { to }
  for index, email in ipairs(to) do
    to[ index ] = '<' .. tostring(email) .. '>'
  -- message headers and body
    headers = {
      to = table.concat(to, ', '),
      subject = subject,
      ['Content-type'] = 'text/html; charset=utf-8',
    body = message
  -- fixup from field
  settings.from = '<' .. tostring(settings.from) .. '>'
  settings.rcpt = to
  return smtp.send(settings)
-- Init Script
mail( 'mymail@mail.com',  'Restart LogicMachine',  'my message body')
-- Sync before reboot
os.execute('sync')
You can add a notification to the init script. A short delay might be needed as internet connection might not be ready when the script starts.
As for reboot via a script it should not be needed at all. If you are experiencing a bug that requires rebooting LM to fix it then let us know and we will look into it.
(08.04.2023, 18:13)merel Wrote:
-- Init Script
Sorry about the late reaction.
It is working, but i set a delay of 5 minutes.
Because when there is a full power off, my network will start up, before i sent the message.
