Script for Reboot
Hello Daniel.
Is it possible to create a script for reboot the LM?
Try this:
os.execute('reboot')
Be careful with this, if you loop controller in constant reboot, the only way out is hardware factory reset.
(05.04.2023, 19:09)palomino Wrote: Hello Daniel.
just make backup defore implementing ths code))
Is it also possible to get a notification when it restarts?
(08.04.2023, 13:58)Dré Wrote: Is it also possible to get a notification when it restarts?
123456789101112131415161718192021222324252627282930313233343536373839404142434445
-- Common Function function mail(to, subject, message)   -- make sure these settings are correct   local settings = {     -- "from" field, only e-mail must be specified here     from = 'servis@servis.com',     -- smtp username     user = 'username',     -- smtp password     password = 'password',     -- smtp server     server = 'smtp.myserver.com',     -- smtp server port     port = 25,     -- enable ssl, required for gmail smtp --    secure = 'sslv23',   } -- port 465     local smtp = require('socket.smtp')   if type(to) ~= 'table' then     to = { to }   end   for index, email in ipairs(to) do     to[ index ] = '<' .. tostring(email) .. '>'   end   -- message headers and body   settings.source = smtp.message({     headers = {       to = table.concat(to, ', '),       subject = subject,       ['Content-type'] = 'text/html; charset=utf-8',     },     body = message   })   -- fixup from field   settings.from = '<' .. tostring(settings.from) .. '>'   settings.rcpt = to   return smtp.send(settings) end
-- Init Script mail( 'mymail@mail.com''Restart LogicMachine''my message body')
-- Sync before reboot os.execute('sync')
You can add a notification to the init script. A short delay might be needed as internet connection might not be ready when the script starts.
As for reboot via a script it should not be needed at all. If you are experiencing a bug that requires rebooting LM to fix it then let us know and we will look into it.
Sorry about the late reaction.
It is working, but i set a delay of 5 minutes.
Because when there is a full power off, my network will start up, before i sent the message.
